I started to have problems with refusal to print plus error messages, including damaged or clogged printhead; replace printhead. I removed the head, and cleaned it with a kit I had bought several years and used successfully on another Canon. This time, only the black would print, not one color drop. A poster on fixya said that when the waste ink pad is full, the related color or black on this model, anyway will not print. I don't want to waste my $50 on a new printhead if the pad is full and it won't print anyway. If it's possible for a mere mortal to empty/clean the waste ink, please give instructions. I love this printer, and do not see a comparable new one for a reasonable price. Thanks.
Http://www.startcopy.ru/repair/rol_c_ip4500.htm
is the same
Testimonial: "Thanks for trying to help, Sergey. Photos showed what looked like a totally disassembled printer, with instructions in Russian. My skill level is not up to the task. I'm sure your answer will help others fix their Canon printers, though."
SOURCE: Can anyone tell me how to remove the print head?
Take out the cartridges first, then the printhead will come out easily. Grab it at the top, and gently Pull out. That'll do it good Luck!!
SOURCE: Waste ink absorber almost full-Canon S900 inkjet
It doesn't matter if you change (wash) the waste ink pad absorber or not, if you reset the error code il will work ok. The waste ink sponge can be full if you had a lot of cleaning done since using the printer, fact is that latest after the error appears the second time, you had to clean it.
WASTE INK TANK RESET PROCEDURE
Canon BJ F900, F890, F700, F500, S900, S820, S750 and S520
Turn off the printer.
Press and hold the RESUME button, then press and hold the POWER button.
Release the RESUME button, then press and release the RESUME button two more times in succession. (youre still holding the POWER button during this). The printer mechanics will move momentarily.
You are now in Service mode.
Pressing the RESUME key will select a function; for example, pressing RESUME 4 times will select the clear waste ink counter function. The lamp will alternate color with each key press.
1. service/factory test printout, including ink sensor check
2. EEPROM info printout
3. EEPROM initialization
4. Clear the waste-ink counter
5. Printer model setting. (more selections beyond this- leave this alone)
After selecting mode, press the POWER button to commit the change, and return to the top of the function selection menu. Pressing the POWER button again turns off the printer for a restart.
SOURCE: smeared lines
Okay, this was the problem I posted a few days ago. It's fixed now, so in case you have the same problem with smearing, here's what the help desk from Canon suggested: Open the cover and remove the ink cartridges. There is a gray lever in front of the cartridges. Lift this lever and the printhead can be easily removed.
Our printhead had a buildup of black ink on the surface. I carefully removed this with rubbing alcohol. I let the printhead dry and replaced everything. No more smearing. Imagine a help-desk that actually helped!
SOURCE: waste ink absorber is full
Hi!
The printer counts every single droplet ejected by the print head due to waste ink absorber capacity. When the waste ink counter rise to about 90 % the printer shows message 'Waste Ink Absorber Near Full'; in this stage we can still continue printing by pressing Resume button until waste ink absorber capacity reach 100% and 'Waste Ink Absorber is Full' appears.
To fix this problem you have to reset waste ink counter to 0%. Even though we can just reset waste ink counter without resetting waste ink counter, it strongly recommended that you replace waste ink absorber to prevent ink flooding inside the printer.
To reset waste ink counter, perform the following steps:
In this stage your printer has operated as usual.
Regards,
SOURCE: Canon IP 90 clogged printhead nozzles. How to remove printhead?
To avoid drying of the Print Head and clogging of the nozzles, note the following.
*When you turn off the Machine
Follow the procedure below to turn off the machine.
1)Press the ON/OFF button to turn off the machine,
2) Confirm that the POWER lamp has gone out.
This takes a few seconds or as long as 20 seconds.
3) Unplug the power cord from the wall outlet.
If you are using a power outlet strip, you can switch off instead.
When you press the ON/OFF button to turn off the machine, the machine automatically puts a protective cap on the Print Head to prevent the ink from drying. If you remove the power cord or switch off the power outlet strip before the POWER lamp goes out, this capping will not be done properly, causing the Print Head to dry and clog.
* When You are not Using the Machine for a Long Time.
When you are not using the machine for a long time, print or copy in both black and white and in color or pertorm Print Head Cleaning, about once a month to prevent degradation of the Print Head.
Numerous nozzles are installed in the Print Head for high -precision printing. Just as the uncapped tip of a ballpoint pen or marker becomes dry and unusable if it is not used for a long period of time, the print nozzles becomes blocked by dried ink. Periodically printing or cleaning of the Print Head can prevent this blockage.
Note :
*If the printed area is traced with a highlight pen or paint-stick or stained with water or sweat, ink may blur depending in the paper.
*If the print head nozzles get clogged , printouts will become faint or particular colors will not be printed properly.
When Printing Becomes Faint or Colors are Incorrect.
When printing becomes faint or colors are incorrect even if the ink remains in the ink tanks, the print head nozzles are probably clogged. Print the nozzle check pattern to confirm the condition of the nozzles and then perform the Print Head Cleaning.
Note : Before performing maintenace
*Open the Scanning Unit (Printer Cover) and make sure that all lamps for the ink tanks are lit red.
-If any one of the lamps is flashing slowly, the associated ink tank is running low. You can continue printing for a while, but we recommend you to have replacement ink tank available.
-If any one of the lamps is flashing fast, the associated ink tank is emty. Replace the ink tank.
If an ink tank is flashing fast even though ink remains in that ink tank, it is inserted into the wrong position. Make sure that the ink tank of the correct coloris inserted in each position matching the label.
-If the ink lamp is not lit, the tank is not set properly. Press the <PUSH> mark on the ink tank until the tank clicks into place. Make sure that all the packaging material is peeled off the ink tank.
*Increase the print quality setting in the printer settings.
Step 1 : Printing the Nozzle Check Printer.
1) Make sure that the machine is turned on, open the Front Feed and extend the Output Paper support.
2)Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder.
Set the Paper Thickness Lever to the left.
3) Press the Paper Feed Switch to select the paper source where you have loaded paper.
4)Print the nozzle check pattern.
a) Press the Menu button.
b) Use the right and left arrow buttons to select the Maintenance/settings, then press the OK button.
The maintenance /setting screen is displayed.
3) Use the right and left arrow buttons to select Maintenance, then press the OK button.
The Maintenance screen is displayed.
4) Use the Up and Down arrow buttons to select the Nozzle check and then press the OK button.
The pattern confirmation screen is displayed.
5) Use the Up and Down arrow buttons to select Yes and the press the OK button.
The nozzle check print is printed, and the pattern confirmation screens are displayed alternately.
Examine the pattern and take the appropriate action.
Step 2: Print Head Cleaning
Clean the Print Head if lines are missing or if white streaks appear in the printed nozzle check pattern. Cleaning unclogs the nozzles and restores the print head condition. Note that cleaning the Print Head causes used inl to be absorbed in the ink absorber. Cleaning the Print Head consumes ink, so perform Print Head Cleaning only when necessary.
1) Make sure that the machine is on, open the Fron Feeder, and extend the Output Paper Support.
2) Load a sheet of A4 or Letter-sized plain paper in the Auto Sheet Feeder or the Front Feeder/
4) Start Print Head Cleaning.
b) Use the right and left arrow button to select Maintenance/settings, then press the OK button.
c) Use the right and left arrow buttons to select Maintenance, then press the OK button.
d) Use the Up and Down arrow buttons to select Cleaning and then press the OK button.
The confirmation screen is displayed.
e) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Print Head Cleaning starts.
Do not perform any other operations until Print Head cleaning finishes. This takes about 50 seconds.
The pattern print confirmation screen is displayed.
f) Use the Up and Down arrow buttons to select Yes and the press the OK button.
Note : If the problem is not resolved after performing steps 4 and 5 twice, try Print Head Deep Cleaning.
If print quality does not improve by standard Print head Cleaning, try the Print Head Deep Cleaning, which is more powerful process. Note that cleaning the Print Head causes used ink to be absorbed in the ink absorber. Print Head deep Cleaning consumer more ink than the standard Print Head Cleaning, so perform this procedure only when neccessary.
1)
d) Use the Up and Down arrow buttons to select Deep Cleaning and then press the OK button.
Print Head Deep Cleaning starts.
Do not perform any other operations until Print Head Deep cleaning finishes. This takes about 100 seconds.
5) Check the condition of the Print Head.
a) Print the nozzle check pattern to check the print head condition.
If a particular color is not printed properly, replace the ink tank of that color.
b) If the print head nozzles are still not cleaned, turn off the machine and perform another Print Head Deep Cleaning after 24 hours.
c) If this does not solve the problem, the Print Head may be damaged. Contact your Canon service representative.
Hope this helps.
Please rate my response.
Thanks.
Have a good day.
jay,
close to the facts:
never(!!!!) clean a brother printhead by soaking it into a solution what so ever it contains!
The printhead is a piezo one and totally diffrent from hp or canon bubblejet which heats the ink to print while the brother (and epson) ones have a bi-metal insides which "fires" ink onto paper when needed. The outward cleaning solution will destroy the bimetal and the electric inside the built-in-one printhead.
Do use only dye ink for brother printers. In fact there is a filter inside the printhead in front of the nozzels. pigmented ink has particles (which give the color to the "water" where dye ink is already "colored water" without partikles!) which definitley cloggs the filter and therefor the nozzels! The filter cant be cleaned because its part of the printhead.
The machine has a counter built in which counts the cleaning cycles of the machine. There are small clying cycles which the machine does by start printing (some 0.5 ml will be waisted) and the manual cleaning cycle started by user which needs a 3ml amount of ink.
The machine has a built in waistinktank like all inkjet printers have. The engineers of brother have set the counter to an amount of taking up cleaning ink that will last for 2.5 - 3 years in normal use (and using original ink!). When the waistinktank has taken up the max of ink the machine will display error:cleaning and refuses to print anymore. The tank has to be replaced and the error (error 46/error:cleaning) has to be deleted within the eeprom.
Some solutions:
Run the cleaning cycle twice with original brother ink carts placed in the printer.
If you are lucky the nozzels (or filter) will be trouble free again.
If you dont see any success the printhead (or partially the filter) is clogged and has to be replaced by a new one.
Do use only (empty) original ink carts with a refill dye ink. Mix it up (:-)) with a trace of printhead cleaning solution by 1:10 for the C/Y/M colors only. You can refill an amount of 11 ml (1 ml cleaning solution + 10 ml ink) into the C/Y/M ones and an ink-only of 20 ml into the bk one.
In case the waistinktank is filled up and error sign appears search the forum here for error 46 and buy a new waistinktank as a spare part from a service dealer.
