Base here
LG 52LG70 UG TV Stand Base
SOURCE: putting the tv stand back on the tv
these are removal instructions should be helpful though
Open up the panel on the back of the TV which covers the various input
connections. At the bottom of the area previously covered, there are 8
screws (two rows of four screws). Remove them, and the entire stand
should now slide right out of the TV. You can then replace the screws
back in their holes, so you don't lose them. You do not need to
disassemble the stand to do this.
SOURCE: need a relacement tv stand
This company called Amergence Technology a 3rd Party repair center is offering to sell stands for Olevia Brand Televisions.. it was stated they just started to sell them as the stands become available ...
there ph. 866-965-3842
SOURCE: remove stand from LG 50PC5D
There are four screws in the back of the TV above where the stand is. Inbetween the screws is a metal handle that pulls out. These four screws need to be removed and the metal handle pulled out. Then the TV will come off the stand.
SOURCE: How to disengage the stand from an LG 42PC5D
When I tried to do the same I took the same approach but could not pull the stand - is there another safety pin or something like that?
I took out two screws from the back that had been holding the metal top of the stand inside the panel - but when I try to lift panel off it does not move!
SOURCE: I lost the tabletop stand
Tries websites like Amazon.com,Ebay.com to buy a used base stand or a new base stand.
