Question about LG 55LE5400 TV
LG 55LE5400 TV black screen and no audio
Powers on no sound, black screen no backlight
SOURCE:
SOURCE: 32 LG LCD TV
Depending on your electronics skill, they can be replaced with new replacement boards. Usually the inverter boards that drive the backlights tend to blow. Soo its not really an expertise repair unless you know what your doing. The lcd tv's ive fixed the backlights are all on a 2 pin connector.
Posted on Oct 15, 2007
  • 458 Answers
SOURCE: 42" LG Plasma tv, no picture - black screen, but have sound.
Most a likely a problem with your Y-Sustain board which will then not drive the screen giving a black picture. The fuse on the board may be open circuit & need replaced but most likely you will need to have the sustain board replaced.
Posted on Oct 28, 2009
  • 162 Answers
SOURCE: I just bought a LG 55le5400 TV. How do I hook up a
You can use rca cables to hook it up or use the toss link cable if your receiver has that.
Posted on Mar 14, 2011
bugoy31
  • 1238 Answers
SOURCE: I have an LG LCD 55LH40 tv where the screen went black. My directv was doing some kind of reboot because we had a power outage, bad weather, and it restarted and the tv was on and the screen said the
Good day..
that problem is cause of bad inverter board or T-con board..
If you have backlight the problem is T-con board..if no back light the problem is inverter board..
Hope it helps..
Posted on Jun 14, 2012
spr1949
  • 1182 Answers
SOURCE: Our LG 42
Most probably the capacitors in the power supply have burst. Might need attention by a qualified service technician.
Posted on Aug 02, 2012
LED TV screen has flickered momentarily and faded to black. I have sound and power buttons light up. LED solid black, not lit. Bad LED Driver board?
Sounds like Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement. To some models sets, the back-light inverter and SMPS section circuit will be integrated at its main board itself. If so; the main board should be replaced. To some models of sets, all these section circuit will be integrated at its main board. If this is the case, you have to replace the main board.
Jul 16, 2016 | LG Electronics 55LE5400 55LE5400 55 LEDLCD...
LG tv black screen with sound
Hi Tommy,
This is a common problem with LG LEDs. It is a backlight failure. Either the backlights are not receiving the power to drive them or some of the LEDs in the backlight array have failed.
I hope it helps.
Good Luck.
May 25, 2016 | LG Televison & Video
My tv powers on displays the LG logo then makes a high pitched squeal sound from speakers and then flashes on screen (strobe light effect) does not display picture or sound.
LCD TV Repair Tutorial - LCD TV Parts Overview, Common ...
? 11:05
https://www.youtube.com/watch?v=tS4sIpdajVw
Aug 23, 2013 - Uploaded by ShopJimmy.com
Repair review of common LCD TV Problems and Repair Solutions ... input the tv is set to it begins making a high pitched whiningsound. .... I have a LG 47LN5750 that powers on, flashes a good picture for about 1/2 second, then goes dark. ... hi my samsung tvis not turning on is black. and I just replace the ...
#Treat At Home high pitched whine from plasma tv Tinnitus ...
www.aspenridgerentals.com/tinnituscure/?...high%20pitched%20whine%...
LG 50PK540 plasma TV Repair power supply EAY60968801 Part 1-2 ... Sanyo DP42849 with high pitched squeal after replacing power supply. ... In my second daily fix video, I solve a mystery that was making me having to turn off my speakers before I went to be ... The flash is accompanied by an high pitched sound.
TV not turning on; making high-pitched sounds - Tom's ...
Dec 16, 2015 | LG 55LE5400 TV
My LG 55LE5400 TV will not show a picture. The screen is black. I was watching a movie and it just went off.
If your LCD TV or monitor has stopped working, or is displaying one of the following symptoms, then it's a candidate for some new capacitors
- Flickering screen
- Screen image disappears after several seconds
- Dim screen
- Slow start
- Power LED on, but no picture
- Unusual colors and/or lines
The primary cause of LCD TV and monitor failure is caused by faulty capacitors. You can examine the capacitors in your LCD TV or monitor and actually see if they are bad.
If they appear bulged on top, then they need to be replaced.
New capacitors will solve a host of problems in LCD monitors and TV's and will extend the life of your monitor or TV by several years.
Check the cables, connectors and connections.
Take it to a repair shop.
https://www.youtube.com/watch?v=TR2iWN6b-LY
https://www.youtube.com/watch?v=TR2iWN6b-LY LCD TV Repair No Power Power Supply Common Symptoms Solutions How to...
Mar 14, 2015 | LG 55LE5400 TV
Picture freezes then shuts off and restarts.
First of all, shame on LG for not providing support on their product. It sounds like this TV isn't that old. I was just bragging on them to several people this week. Your symptoms sounds like a main board issue. But in order to be sure, proper troubleshooting will need to be done to pinpoint the problem. You will have to pay a diagnosis fee, usually $75 range, but for a 55" late model set, I would say it is worth the money. So sorry to hear this, I'm hearing so many of these late model LED TV's failing left and right.
Nov 21, 2012 | LG 55LE5400 55-Inch 1080p 120 Hz LED HDTV...
I just bought a LG 55le5400 TV. How do I hook up a older receiver that does not have HDMI, or sound for my speakers?
Mar 14, 2011 | LG 55LE5400 TV
LG 55LE5400 TV Logo
278 people viewed this question
Ekse
