Question about Razor Crazy Cart Electric Ride On Pink
Why doesn't it run?
Hello, my crazy cart will not start. When I plug the charger in to charge the batteries the plug turns red for about 4 seconds and then switches to green. When I turn on the cart, it does nothing. However, when it is is the on position, I can hear clicking when I press the accelerator pedal. When off, I don't hear it. So I am assuming I am getting some kind of juice. Could this be batteries? Control Module?
    Top Expert:
  • 11,573 Answers
Try battery first check with digi. volt ohm meter, but yes it could be module.
Posted on Jan 26, 2016
SOURCE:
With new batteries in a EZGO golf cart, when you plug in the charger when the batteries are showing half charge, the charger runs for about 15 seconds, shuts off for 2 seconds, and then back on.
How old is this unit? What is the model number? The newer carts have an smart charger that will tell what is wrong with a flashing code on the charging light.
Oct 23, 2017 | The Computers & Internet
My Wii intec induction charger model G5857 wont charge my Wii batteries.The charger worked 4 1 year.I don't know which is the problem.I don't want 2 spend more money on a new set of batteries/charger.
first are you now using li batteries or nicad batteries
small chargers are battery composition specific
secondly-- chargers for aa /aaa batteries are cheap so get a new charger for the batteries in use
Jan 08, 2017 | Intec Video Game Consoles & Games
Charger wont kick off after fully charged.
Charger won't shut off - Buggies Gone Wild Golf Cart Forum
www.buggiesgonewild.com > ... > Electric Club Car
Sep 27, 2010 - 7 posts - ‎2 authors
But the cart still wouldn't fully charge. After charging the cart, I checked the voltage on the entire battery pack using my meter and then each ... 36 volt powerwise ez go charger not working
Sep 5, 2011
Club car 96 battery charger not turning off
Aug 30, 2011
2001 Club Car Charger Won't kick off
May 31, 2011
48v club car charger wont shut off
Apr 11, 2009
More results from www.buggiesgonewild.com
About Golf Cart Battery Chargers - Golf Cart TalkGolf Cart Talk
www.golfcarcatalog.com/golf-cart-blog/about-golf-cart-battery-chargers/
Jan 24, 2016 | Golf
Charger just workrd at my neighbors, doesn't even make a sound whwn i plug it into my cart. why does it not take a charge?
Measure your total battery voltage. That is measured across the main positive cable and the main negative cable. If you have a 48 volt golf cart and an automatic charger, any pack voltage under 42 volts will not turn the charger on. Your only recourse then would be to charge one battery at a time until you get 42 or higher.
Sep 07, 2015 | Golf
Why does my golf cart battery charger turn off after 6 seconds when battery is partially discharged?
I have seen a charger turn off like that when there is one or more bad batteries. Try a load test on each battery to see if one is bad.
You can do this with a voltmeter. Connect the voltmeter to one battery and make the cart start to move and watch the meter.
If the voltage drops a lot then it could be defective.
Aug 30, 2015 | Golf
Phone says its charging when plugged in but battery doesn't charge
Hello and Welcome to FixYa!
Well, it seems like either bad charging connection. Look, sometimes, it happen, that as soon as you plug in the charger, the charging indication starts showing that the device is under charging mode, but in real its not. You can say, that the charging animation showing on the screen is fake. Secondly, it could be due to bad charging IC in worst case, or can be due to weak battery (in most cases), And to rectify the problem, first you need to try charging the battery with some other OEM charger, Secondly do make sure that there is no carbon deposition on the battery terminals. If the problem still persists, then either the charging IC or the battery is the bottle neck of the trouble. Hope, now you get a wider picture on how to deal with the scenario.
Have a nice day,
Concerned.
Aug 12, 2011 | Samsung Jet S8000 Cell Phone
I have replaced joystick, batteries, motors and the chair still losing lights will go about 1/4 mile and loses all green lights with in 1/2 mile loses all the yellow lights, drove on 1 flashing light for...
Janice check your charger it could not be charging the batteries. Now always charge your batteries overnight while you sleep When you get up lights on the charger should be red and green if they are red and yellow then the charger hasn't fully charged the batteries and overnight should be more than enough time to charge fully. This could indicate a bad battery remember new doesn't always mean good. Like they say always charge before use and this goes for new batteries too you need to charge new batteries nightly for 10-15 days before they start operating at 100%. If when you plug in the charger before bed and the lights are red and green then there is a problem with the charger or the batteries or the charger circuit Hope this helps you
May 23, 2011 | Spirit Activecare /wildcat Foldable Power...
My i-mate does not start
Hello
you just made a "HimaClearJumpCode.exe" run on ur device(this file exists in ur upgrade folder),and now you are stuck in the bootloader mode
1-hard reset ur device(it wont boot,off course)...
2-plug it in the usb port,u should see that ur system has found a new hardware(if it doesn't,change the USB port)
3-now run the himaupgradeUt.exe.
If this does not work,
1-take the battery off device
2-leave ur device for 12hours without battery,so that backup battery drains...
3-put back the battery,recharge and enter the OS(this option wont work if u have erased the ROM)
4-rerun the upgrade...
The battery might be too low to be charged by the charger,if that is the case;
1) Remove the battery from the phone!
2) Take 3 fresh AAA batteries in series (total 3 x 1.5V = 4.5V)
3) Connect the (+) wire to (+) on the battery
4) Connect the (-) wire to (-) on the battery
5) Hold this in place for 60 seconds.
6) Put the battery in your phone
7) Switch on phone and start charging (via USB)
Apr 14, 2011 | i-mate JAM Pocket PC
I took this blackberry bold out of a recycle bin at my school and when i plug it into my dads bb charger the red light comes on but after 10 minutes of charging it still wont turn on.I think its a corrupt...
try this:
JUMP STARTING A BLACKBERRY
1. Plug wall charger into wall and then plug into blackberry
2. Take off back cover and pull the battery out (while it is plugged in still)
3. Wait 30 seconds. The red LED may remain on (tech said it didn't matter).
4. Put the battery back in and wait about 5-10 seconds and it'll begin to boot up (white screen with clock icon).
Jan 28, 2011 | Computers & Internet
Kenko
read the owners hand book
normally the lights stay red until the battery is charged then it goes green
if the power is cut or if you switch the point off with the charger still in it and do not remove the charged battery , the battery will discharge through the charger
Mar 27, 2017 | Kenko MC-4 DG for Nikon AF 2x (MC4AFNDG)...
Razor Crazy Cart Electric Ride On Pink Logo
207 people viewed this question
Top Razor Health & Beauty Experts
Tom Chichester
Are you a Razor Health and Beauty Expert? Answer questions, earn points and help others
