If it has bluetooth try this hope it helps.
1. Press and hold the multi-information meter switch for about 2 seconds or more to switch from the setting mode screen to the menu screen.
Refer to "Changing the function settings (when the ignition switch is "ON")".
2. Lightly press the multi-information meter switch to select (language cooperative control).
3. Press and hold the multi-information meter switch to switch in sequence from A or 1 (language cooperation enabled) ? M, 2 or P (language cooperation disabled) ? A or 1 (language cooperation enabled).
The setting is changed to the selected condition.
Note
? The memory of the language cooperative control is erased if the battery is disconnected, and it returns automatically to A or 1 (language cooperation enabled).
? The language display modified with the language setting can be switched in the following manner.
• When A or 1 (language cooperation enabled) has been selected with the language cooperative control, the language for MITSUBISHI Multi-Communication System (MMCS) (if so equipped) or the Bluetooth® 2.0 interface (if so equipped) is automatically changed to the language selected for the multi-information display.
• When M, 2 or P (language cooperation disabled) has been selected with the language cooperative control, the language for MITSUBISHI Multi-Communication System (MMCS) (if so equipped) or the Bluetooth® 2.0 interface (if so equipped) is not automatically changed to the language selected for the multi-information display.
