Cell Phones Logo
d
debra booth Posted on Jan 26, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I have http error 404 how do I fix it - SGH Samsung Cell Phones
Eddie Tam
Level 3:
  • Samsung Master 294 Answers
  • Posted on Jan 26, 2016
Eddie Tam
Samsung Master
Level 3:
Answers
294
Questions
0
Helped
216816
Points
3049
Samsung SGH Cell Phone: Http 404 error, how to fix:
Hello. A Http 404 error is not fixable by you. It is not caused by your cell phone/device. A Http 404 error is basically a "dead end" ..like you walked down a pathway that lead to a wall.
Possible cause:
(1) A Http 404 error means that you either entered a typo in your link address
or
(2) The Owner of the website deleted that page or file or image and it no longer exists
or
(3) The Website Hosting company is down for maintenance, so that web page that you visited is not working right now.. check back tomorrow to see if their service is back online.
or
(4) If the link was clicked on from a Website, then that web page provided a broken link. Report the broken link to the Website so that they can fix it.
How to remove google 404 error?
A 404 error is an HTTP status code that indicates that the page you were trying to reach on w website couldn't be found on their server. There are billions of user's faces this problem at every second and minute and no can escape for that. There are multiple reasons behind the error 404 code and it never means you can't fix this problem. But there are many users always ask how to remove Google 404 error and if you are one among those, then you can easily fix this problem by applying some easy troubleshooting steps.
Here are the steps to fix 404 errors on Google:
·Check the URL: Sometimes entering an incorrect URL may also cause several of error including the 404. So make sure that you have entered the URL of that particular website correctly.
·Refresh the page: You can also refresh the page for that you are confronting this error by pressing the F5 key.
·Clear the Caches: By clearing the caches and history of that page you may also fix the problem of 404 errors in a very simple manner.
·Check the internet connectivity: Make sure that you are working on an active internet connection because sometimes bad internet connectivity also occurred several problems.
If you are still confused that how to remove Google 404 error even after applying the above-described steps, then you can contact the customer service team and avail the instant assistance to fix this problem.
Get more info from here:-
https://www.tecask.com/blog/how-to-remove-google-404-error
2answers
What is the Difference of between soft 404 and 404 errors
The WordPress error 404 is an infamous error and it means that the page or source you are looking in a website is either removed or changed. Due to nonexistence of the page, the request of users unable to reach the server and it cause 404 error
Potential solutions to fix 404 error are as follows:
Refresh the webpage by pressing F5 or CTRL+R because sometimes only refreshing the page work for users
Clear cache and cookies of the website and this step will solve error 404 from your website
Change the DNS server might eliminate the 404 error of the website
Check yours. Htaccess file and see if the issue is causing because of the file. If it is causing because of .htaccess file then rename the file and then reload the web page. If the website has returned back to its normal mode then you can create a new copy of. Htaccess file and upload it to the server.
These are some of the possible solutions to fix the error 404, but still, you want flawless solutions, then contacting the WordPress engineer and support team is always the best move.
Google 404 that's an error What is 404?
A 404 error is an HTTP status code that means that the page you were trying to reach on a website couldn't be found on their server.
Technically, an Error 404 is a client-side error, implying that the error is your mistake, either because you typed the URL in wrong or the page has been moved or removed from the website and you should have known. Another possibility is if a website has moved a page or resource but did so without redirecting the old URL to the new one. When that happens, you'll receive a 404 error instead of being automatically routed to the new page.
Note: Microsoft IIS web servers sometimes give more specific information about the cause of 404 Not Found errors by suffixing a number after the 404 as in HTTP Error 404.3 - Not Found which means MIME type restriction.
2answers
404 error message
Here is a guide about 404 error messages in general:
Getting 404 Not Found Error Here What to Do
Here is a YouTube video about 404 Error Messages:
Http error 404 not found
Technically, an Error 404 is a client-side error, implying that the error is your mistake, either because you typed the URL in wrong or the page has been moved or removed from the website and you should have known. Try another URL or check with the site your are trying to contact to see if they are still active. Hope this helps.
2answers
Slotomania will not open - error 404 nginx/1.0.8
No matter the reason for the 404 error, there is plenty you can do to try to get to that page you were after:
How To Fix the 404 Not Found Error
Retry the web page by clicking the refresh/reload button or trying the URL from the address bar again. The 404 Not Found error has been known to appear on occasion even if there is no real issue so a simple refresh will often load the page you were looking for.
Check for errors in the URL. Often times the 404 Not Found error appears because the URL was typed wrong or the link that was clicked on points to the wrong URL.
Move up one directory level at a time in the URL until you find something. For example, if www.w.com/a/b/c.htm gave you the 404 Not Found error, move up to www.w.com/a/b/. If you get nothing here, move up to www.w.com/a/. This should lead you toward what you're looking for or at least confirm that it's no longer available.
2helpful
7answers
404 not found
The 404 or Not Found error message is a HTTP standard response code indicating that the client was able to communicate with the server, but the server could not find what was requested.
The web site hosting server will typically generate "404 - Not Found" web page, when users attempts to follow a broken or dead link, hence the 404 error is one of the most recognizable errors users can find on the web.
A 404 error should not be confused with "server not found" or similar errors, in which a connection to the destination server could not be made at all. A 404 error indicates that the requested resource may be available again in the future; however, the fact does not guarantee the same content.
2answers
404 not found
This is a response from the Youtube server, saying it cannot find what was asked for. Many Youtube clips disappear unexpectedly, because of copyright infringements or other problems.
1helpful
2answers
When i click on utube screen says 404 not found
Try to play another video if that shows 404 error so it means there is some problem in your internet connection. And if the video play so it means the video whcih you want to play before and showing 404 error is removed by the copyright rules violation on you tube.
Top Samsung Cell Phones Experts
Ronny Bennett Sr.
Ronny Bennett Sr.
Mike Cairns
Mike Cairns
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
