Computers & Internet Logo
Sue Dowell Posted on Jan 26, 2016
Internet links won't open in win live mail, using win7
When I click on a link msg reads no file attached to complete action
  • Carlos L. Burgos
    Carlos L. Burgos Jan 30, 2017
    Hello there, Sometimes, if you can uninstall the live mail, or revert to the time that work, using restore point will help set up things againg. Others, its a problem with popup blocking, have to disable and see. good luck
Ibrahim
Level 1:
New Friend:
  • Contributor 3 Answers
  • Posted on Jan 29, 2017
Ibrahim
Contributor
Level 1:
New Friend:
Answers
Questions
0
Helped
668
Points
5
These applications as well require to have enabled popups so you can open links.
Go to internet settings and enable popups, it shall open for you.
Anthony Townes
Level 1:
Problem Solver:
  • Contributor 29 Answers
Anthony Townes
Contributor
Level 1:
Problem Solver:
Answers
29
Questions
0
Helped
9215
Points
61
Opening from a Desktop app is usually the problem... try opening directly from the browser to read the messages... as far as the desktop , there are tons of settings and updates that must be done.. it could take a lot of time and trial an error.. just make sure your using the most updated version of the software otherwise your stuck using the browser only.
5 Related Answers
Anonymous
  • 80 Answers
  • Posted on Sep 23, 2009
SOURCE: Internet Explorer 8 External Link Problem
hi,
1.make internet explorer as a default web browser.tools - IE options - programs, there you have option.
2.run this link: http://karthik.realslimshady.googlepages.com/outlooklinks.reg
3. if it still doesn't work check it in safe mode with networking, if it works there disable securiy software once and see.
Anonymous
  • Posted on Feb 07, 2008
SOURCE: outlook express
This is NOT an issue with outlook... You can able to open any kind of links from outlook as usually clicking on the link. This issue may be because of firewall which blocking the access of the url from outlook. If you open the same page in your web browser directly typing the path of that page it will surely open. If you are using outlook in your office then try the same from your home and see the positive result!
Anonymous
  • 45 Answers
  • Posted on Feb 13, 2008
SOURCE: Unable to open attachment recieved as forwarded mail
See if this helps:
http://www.tutorials-win.com/OutlookGen/Cannot-open-535339/
Cheers -Parveen
Anonymous
  • 615 Answers
  • Posted on Jun 27, 2009
SOURCE: front page opens when I click on internet link in
open a web browser>tools>Internet options>
enter the u r home page website name in the field> press apply> ok
it solves u r problem
Bharathidasan Neelakantan
  • 50 Answers
  • Posted on Oct 10, 2010
SOURCE: links using internet explorer 8 will not open,
This is possibly due to the phising filter in the IE 8, to resolve this issue follow the below steps.
Add the facebook.com in to trusted sites loaction, and disabling the add ons in the browser.
1) Check for your internet security settings, or activex or java settings
2)you may try to access the links, without any add-on's to verify if it works fine.
Click the Start button,
Click All Programs and click Accessories
Cclick System Tools, and then click Internet Explorer (No Add-ons).
Verify if it works fine and if it works, here's what you can do:
ā€¢
Disable it. If an add-on causes repeated problems, disable it by using Add-on Manager in Internet Explorer.
ā€¢
Report it. When prompted, you might want to report the problem to Microsoft. The report is anonymous and requires nothing from you except your permission. These reports are used to improve our products and to encourage other companies to update and improve theirs.
3) You may also try to optimize Internet explorer on your computer and later verify if you are able to access the links.
Access the link below and follow the steps to optimize Internet explorer.
http://support.microsoft.com/kb/936213
4) If the issue persists, you may try to reset the internet Explorer settings on your computer and verify if you are able to fix the issue.
To Reset Internet Explorer Settings feature, follow these steps:
1. Exit all programs, including Internet Explorer (if it is running).
2. Type the following command in the Start Search box, and then press ENTER:
inetcpl.cpl
The Internet Options dialog box appears.
3. Click the Advanced tab.
4. Under Reset Internet Explorer settings, click Reset. Then click Reset again.
5. When Internet Explorer finishes resetting the settings, click Close in the Reset Internet Explorer Settings dialog box.
6. Start Internet Explorer again.
Access the link below to know more about resetting Internet Explorer:
http://support.microsoft.com/kb/923737
Links won't open explorer
You have to Set Internet Explorer as a default browser then you will be able to open all your links in Internet explorer.
You just need to go to the Internet options. you can see below image for this.
After clicking on Internet Options you will see the screen as shown in below image.
Now just click on Program and you will see the same screen as show below. After clicking on Program tab click on Make default button and then click on OK button at below.
Now you have set Internet Explorer as your default browser. Now when you click on any link or hyperlink it will open in Internet Explorer.
1helpful
I don't know how to open the attached files
When you open your mail, after reading it, at the bottom of the mail, you would see your attachments, there is a 'view' link. You click on this if you just want to view the file. Then there is a 'download' link, you click on this if you want to download the file. When you download, it would provide you with the option to either 'open' or 'save' the file. Choosing 'open' will open the file. You would then have to save it onto your pc. Choosing 'save' would automatically save it on to any location you specify.
I hope this was helpful to your plight?
Have a nice day.
Scan page > send to my email account > email scanned page?
Follow these steps :
•1
Place your scanned messages in an easy-to-find folder or on your desktop so that you can quickly locate the files to send them.
•2
Launch your e-mail application, such as Yahoo! or Gmail, and create a new message. Enter the recipient's address in the "To:" field and type in your note in the body of the e-mail message.
•3
Click the "attach" link or button in your open message to append the photos and scanned messages to the e-mail. This action causes a box to automatically appear, which allows you to locate and select your desired photos and messages. Once you've selected the file you would like to attach, click a button like "Done" to complete the link between your files and the e-mail. Alternately, some mail applications, such as Mac OSX mail, allow you to click and drag the files to the body of the message to create the attachment. If you need further instruction on creating an attachment, see your e-mail provider's "Help" or "FAQ" page for guidance.
•4
Click the "Send" button in your e-mail message to send your photos and scanned messages. The e-mail may take longer than normal to complete the delivery process, depending on the number and size of the files that you are sending.
Remove virus from account
1. Open Yahoo Mail. Use your Yahoo! user ID and password to sign in to Yahoo Mail. Open the email message suspected of containing a virus.
2. Find attachments. The attached files are in the header section above the body of the email. The names of the attachments will appear as blue, active hyperlinks, taking on the actual saved file name given by the sender.
3.Initiate automatic virus scanning and cleaning. Look for another link labeled "Scan and Download Attachment" and click it. If this link does not show, you may have to click directly on the attachment's file name. Look for the alert "Scanning attachment for viruses." The alert may appear for less than a second, dependent upon the size of the file; if you miss the brief message it is not important.
4. Wait and read results. After the virus scan completes, if no virus is detected, you will be given the go-ahead to download the attachment. If a virus is detected, Yahoo Mail will try to automatically clean the attachment, and then present the option to download.
Hopefully, it may help to protect your Email account.
Oct 18, 2010 • Yahoo Mail
When i left click on a link to another page, nothing happens. msg reads "could not perform this operation because the defalt mail client is not properly installed." help please
Strange... open your Internet page. Go to Tools, Internet Options, Programs. What shows as your default mail client? Try changing it from that to another and try left clicking a link and let us know what happens.
1helpful
How to scan to email
dear customer,
these are some of the ways to do it.. hope its useful..
VistaScan - Scan to Email
VistaScan's direct email link requires either a MAPI (Microsoft Exchange compatible system) or VIM (Lotus cc:Mail system) messaging program - these are commonly used on corporate networks and aren't installed on normal consumer PCs - home and small business users can scan-to-email via PageManager or by attaching images as described below.
VistaScan 3.1 scan-to-email preferences for the commercial MAPI and VIM messaging systems - to reduce the size of file attachments the JPEG file format is recommended.
MAPI programs include Microsoft Outlook 97 and 98 (which can also be used with normal Internet mail accounts) and the latest Netscape Messenger client.
Outlook 98 is a commercial software package (not included with Windows), with support for Internet mail systems, Exchange Server or Lotus cc:Mail messaging servers. outlook98.gif
VistaScan 3.1 application used with Microsoft Outlook 98 - scan-to-email is selected as the destination for the image When VistaScan is used with either a MAPI (Exchange) or VIM (ccMail) mail system it will detect the presence of the software via the Windows registry and automatically launch the client and a new message window, with the single file attached - the message must then be written and sent before the scanner driver can be used again.
Sending images to Email Clients using Presto PageManager 4.0
Presto PageManager is a useful way to capture and archive scans before sending them to another program (eg image editor, word processor) or to print. A few email programs can be linked with PageManager, allowing an image to be "dropped" on a Application Button to automatically open a new message with the scan attached. Microsoft Outlook 98, Netscape Messenger (aka Netscape Mail), Lotus cc:Mail and Eudora Pro 3.0 can all be added as email applications - Outlook Express, Compuserve and AOL cannot be directly linked (these are limitations of the mail programs, not of PageManager!).
pmoutlookbutts.gif comm46butt.gif OutLook Express cannot link with PageManager - a new email won't be opened when selected. PageManager adds an Outlook Express button automatically. Outlook 98 will correctly open a new email and attach the scan(s). PageManager won't setup Outlook 98 automatically, it needs to be Registered as a new application. Netscape Mail will correctly open a new mail with attached scans when selected. The Application Button is setup automatically by PageManager.
Preparing Files for Email Clients
As many Internet email programs do not support Exchange or cc:Mail, the two commercial mail systems integrated with UMAX software, you may have to prepare your scans: the images to be sent need to be saved on your hard disk in a suitable file format, ready to be "attached" to an email.
In general it is better to send as small a file as possible by email, as the image has to be transferred to the Internet over a relatively slow modem link - most users prefer a compressed file format such as JPEG (.jpg). This compresses your scan to a fraction of the original size, although it does slightly reduce the quality of the images.
There are three ways you can save your scans to disk:
1. If you use the VistaScan program (Start, Programs, VistaScan 3.x, VistaScan) you have several choices in the "Scan To" box (Advanced mode).
Click on the Floppy Disk icon - this will then use the settings in the VistaScan preferences:
For emailing scans we recommend the JPEG format - check where the scans will be saved (which directory). File names are created automatically - scan1.jpg, scan2.jpg etc.
2. If you normally scan your images in to PageManager you can export them to your hard disk - right-click on the thumbnail view and choose 'Save As...':
Choose a file location and select the "Save as type" file format.
3. If you are aquiring the VistaScan driver via any other application (eg Adobe PhotoDeluxe) then you should have options to save the images and to change their formats - please refer to the instructions for each application for for further advice.
Attaching images to an Email
All email client programs will allow you to combine file atachments and your text in to a single message for sending - although there are small differences in the way attachments are encoded you normally only need to customise options if sending to someone with an Apple Mac, which supports slightly different graphics file formats. Below are instructions for attaching files in some of the more common email programs:
America OnLine (AOL) (3.0I)
In the Email menu choose Compose Email (Ctrl+E):
At any time while you write and address your email you can click on the Attach icon on the left of the window - this then lets you select the files to be sent.
Compuserve (CIS) (4.0)
In the Compuserve program choose "Create New Mail" from the Mail menu:
During writing and addressing your mail message you can click on the button "Attach File:" - this lets you browse your computer to select the scans to be sent. To make finding the files easier, change the "Files of type" setting to "Graphics Files". Once the files are selected Compuserve shows a second window of encoding options - the default (Binary) will be suitable for almost all emails.
Microsoft Outlook Express
Outlook Express is one of the most common Internet mail clients, and is included with many Windows 98 systems and on ISP disks - this basic mail program also lets you attach files to your emails. Click on the Compose Message button:
While writing your email message you can click on the paper clip icon (shown above) or choose "File Attachment..." from the Insert menu.
Netscape Mail / Netscape Messenger (Communicator 4.6)
The most recent version of Netscape Mail can be linked to PageManager or the VistaScan driver, however many users want to attach scans in the normal way - click the New Msg button to open a Composition window:
While writing your email message click on the Attach button and choose File... - locate and select your scans.
3answers
Unable to open e-mail attachment
Open Files with .MSG File Extension Do you want to open a message with the Outlook .MSG file extension? The Encryptomatic MSG File Viewer makes it easy access Outlook MAPI message files (.msg files) created in Outlook 2000/XP/2003.
MSG Viewer reads .msg files encoded in western characters. It will display the text contents of the .msg file on your monitor. You can also print the message, save it to a text file, and extract file attachments.
Easy to Use Encryptomatic's Outlook .MSG Viewer is simple to use. It may be optionally installed as the default .msg file handler. This enables you to display a .msg file by simply double clicking it.
Extracts File Attachments from Outlook .MSG Message Files
Users can extract and save to disk any file attachments that were included in the Outlook .msg file, a useful feature not found in other viewers of this price class. To extract email attachments, just double click on the file attachment and save it to a directory.
viewer-screen.jpg What it Doesn't Do
The MSG Viewer is designed to give you quick access to an .msg file's text contents, file attachments and header information. It does not render colors, formatting or graphics, and it is not a full featured substitute for Outlook. With an RTF message with colored text and font formatting, the text will appear in black and white and the paragraph formatting will be lost (as in the message above). MSG Viewer displays only Western characters.
Top Microsoft Computers & Internet Experts
Grand Canyon Tech
Grand Canyon Tech
k24674
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
