Amana NED7200TW Electric Dryer Logo
L
Linda Posted on Jan 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
It dries great and doesn't continue to run, however, on/off light still stays on even after it's done.
Jorgie the appliance guy
Level 3:
Top Expert:
  • Amana Master 5,639 Answers
  • Posted on Jan 28, 2016
Amana Master
Level 3:
Top Expert:
Answers
5639
Questions
Helped
1523163
Points
32630
Dryer runs then shuts down wont start up for an hour:
Bad motor windings
Gas Dryer no heat: or shuts down soon after heating CHECK:
Thermal Fuse
If the air flow in the dryer is restricted, the temperature in the heating chamber can get hot enough to blow the thermal fuse. If the fuse blows, it cuts power to the coils that control the gas valve. The fuse is usually mounted to the exhaust duct just inside the back panel. You can check its continuity with an ohmmeter. If, after disconnecting the fuse, you get any reading other than 0 when you touch the leads of the meter to its terminals, it has blown. There's no way to restore it -- you'll have to install a replacement.
Igniter and Gas Valve Coils
TEST with a multi meter: The igniter is an electric conductor that works like the element in an electric heater, glowing hot enough to ignite gas when you turn on the dryer. This conductor can burn out, and when it does, it may glow, but it won't get hot enough to ignite the gas. At times it may give a reading of continuity yet fail mechanically and not get hot enough to ignite flame though it gets hot and glows and even may show Ohms or continuity ( close circuit) ?
Occasionally, the Gas safety valve and the electric coils that control the gas valve are defective -- they can wear out when the dryer gets old. When this happens, the igniter glows, but gas never enters the heating chamber or does not stay consistant.
Performing a continuity test on either part will help you determine whether or not you need to replace it. But the coils should also be tested for amount of resistance as well as Ohms. As they may be showing ohms yet not putting out enough resistance to keep proper gas pressure flowing. Most coils should show at least 1300 ohms ( GIVE OR TAKE 150 OHMS). Anything significantly less Thus u get an ignition but then it soon goes back out. The flame does not stay lit.
Air Flow and Heat
The motor that drives the tumbler also drives a fan that circulates air through the heating chamber and the tumbler and expels it through the vent. If the air can't circulate, perhaps because of lint blockage, the heating chamber overheats, which prompts the cycling thermostat to turn off the gas. The thermostat resets when the chamber cools, but the chamber heats up quickly and the thermostat again shuts off the gas. The result is that the temperature in the tumbler doesn't stay hot, and your clothes take longer to dry, if they get dry at all.
Warning
There's a big difference between a dryer that doesn't heat up at all and one that just doesn't get hot enough to dry your clothes. In the first instance, the problem is usually a defective part, and things should be back to normal after you replace it. In the second instance, the problem is caused by restricted air flow, and you need to clear the lint filter and vents and take steps to prevent lint build-up. If you don't, you'll use more energy for drying than you need and the dryer may continue to malfunction. Worse, you may have a dryer fire.
GOD IS GOOD !!!! AND THAT IS WHY MY ADVICE IS FREE
it dries great and doesn't continue to run, howeve - dries-great-doesnt-continue-run-hdpcwx0uwo4iizhnlkec22xy-5-0.jpg
it dries great and doesn't continue to run, howeve - dries-great-doesnt-continue-run-hdpcwx0uwo4iizhnlkec22xy-5-5.gifun-hdpcwx0uwo4iizhnlkec22xy-5-5.gif" alt="dries-great-doesnt-continue-run-hdpcit dries great and doesn't continue to run, howeve - dries-great-doesnt-continue-run-hdpcwx0uwo4iizhnlkec22xy-5-9.jpgmg src="/uploads/images/dries-great-doesnt-continue-run-hdpcwx0uwo4iizhnlkec22xit dries great and doesn't continue to run, howeve - dries-great-doesnt-continue-run-hdpcwx0uwo4iizhnlkec22xy-5-14.jpgkec22xy-5-9.jpg" class="h_mi" />
Siemens Dishwasher Fault
there is a water level sensor in the bottom of the machine if this is faulty and stays on, this will indicate to the pump there is water still in the machine. I would check this sensor it might be blocked with debris and has blocked in the closed position. that woudl be the best start for this issue.
i hope this was useful.
Feb 15, 2013 • Dishwashers
Start light keeps flashing - wont run. The normal wash and heated dry stay on too. Called tech support, only thing they could say is that the cycle was interrupted. The cycle never even started, cannot get...
Your dishwasher will do this as a safety in case the element is broken and feeding electrical current into the water. Sometimes just a false reading.
Reset your console by pressing: high temp wash, heated dry, high temp wash, heated dry
When all the lights are on you are set in diagnostic mode. Just hit cancel a you will be able to run yourdishwasher as normal. If this same light appears again then you have a bad element or thermostat.
Please take a second to rate your experience. Feel free to repost again if you have more questions.
Have a great day!
I have a Maytag Neptune gas dryer that is approx 8 yrs old and has worked great as far as drying time. The gas will now light and stay on for 15 seconds and then shut off, in 2 or 3 minutes it will light...
to me it sounds like your venting going out side,if it doesn;t get a clear flow it will come on and off the thermastate inside sencing to much heat.try unpluging the vent then try it if it stays on then you know your answer
Engine management light stays on car dries great been well serviced no unusual knocks
something like O2 sensor will cause the check engine light stay on, not too worries,or you may take it to dealer did a service.(the light may stay on on that year model even after service.)
I have a 01 325 bmw- runs great, however, the service engine light has stayed on continuously. Car was placed on diagnostic computer. I was told that I need cam-shaft exhaust replaced- this is what showed...
I need moe information than just the exhaust cam shaft needs to be replaced, it it's a twin cam I want to know how they determined it was the exhaust cam and not the intake, either can cause fuel mixture to be off to make the check engine light on Unless its is a common problem and a recall on this car. Before I would replace cam I would do a dry and wet compression check to verify that it's the valves. and if the cam needs to be replaced then you need to do both plus the valves. and guide seals as well, even gide seals on the intake could cause faulty reading so if there was no compression test the information is inconclusive more test procedures need to be done before tear down also does it have a rubo? and is it gas or diesel? I need this information to to diagnose properly. Or to narrow it down..
1helpful
DRYER WILL NOT HEAT UP. "COOLING" LIGHT STAYS ON CONTINUOUSLY.
You dry by sensor???
Clean your sensor. The machine thinks the clothes are dry because the sensor is covered with who knows what???
Check your owner manual for the proper way to clean the sensor.
I hope this works for you
a
1helpful
Lights stay on constantly even when not running; does not run aft
That clip is necessary as it tells the dryer when the door is open and when the door is closed. you will have to get a new door switch.
Jul 04, 2009 • Dryers
Top Amana Dryers Experts
Kolbrun...
Virgil Watts
Are you an Amana Dryer Expert? Answer questions, earn points and help others
