Radio Communications Logo
K
Kellai Rodriguez Posted on Jan 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Motorola. Transmits, but why can't it receive?
eradiostore
Level 3:
  • Radio Commun... Master 1,672 Answers
  • Posted on Feb 16, 2016
eradiostore
Level 3:
Answers
1672
Questions
0
Helped
797090
Points
4248
Two issues come to mind:
1) The radio has a different private line (PL) code than the other radios.
2) The radio needs repair. Possibly a bad speaker, or other problem. Try plugging an audio device into the radio and see if you can hear then. If so, you have a bad speaker.
Best regards.
Motorola KEM-P29923 2 Way Radio. It can transmit but cannot receive messages.
There are some ideas here, but also make sure Squelch isn't all the way up, that you aren't on some type of mute and that the Volume isn't at Zero.
https://www.google.com/search?q=two-way+radio+transmits+but+does+not+receive
https://www.google.com/search?q=KEM+P29923
My Motorola T5500 will not receive; transmits fine
Check your code. It is possible you have the code set differently between your radios.
Motorola mh230r 1 works fine the other transmits but won't receive.
Check your programming. It sounds like you have chosen a code number in one radio and the other radio has code turned off (zero).
I have a pair of GXT 850 motorola radios. One receives and transmits, the other only receives. Any ideas
try by changing its chanel and sub chanel if subchanel is not the same it will recive only.. try it..
1helpful
One of my walkie talkie's transmits but doesn't receive...WHY?
Your speaker is blown. The microphone still works but you can't hear any audio. Take it back if there not to old.
Secure motorola router WR850G
If you want set wireless router with connect your internet, in that case you should secure your wireless router.The router transmits and receives data from the modem and computers connected to the network....read more: how to secure your router
One radio receives and transmits the second only transmits does not receive. Is this a setup problem, what am I missing?
You're not trying to use a privacy code on one radio without using the exact same privacy code on the other radio, are you?
Motorola t5720 one buzzes and you can't hear transmission. It transmits to its partner just fine. It just won't receive transmission form its partner, just a loud buzz
Try trading the batteries between the units and see if the problem moves to the other radio. If so, replace the battery pack. If the problem persists, you have a defect radio, which needs replaced.
Best regards.
One receives and transmitts and the other one only receives. Tell me why.
Check your interference code eliminator and Qt filter. The one which transmits & receives is probably set with these in the zero or off position, while the other has it with a number or turned on. Here is a copy of the manual: http://www.giantintl.com/ContentManage/manuals/Moto/T55xx.pdf
Top Radio Communications Experts
eradiostore
eradiostore
 Grubhead
Grubhead
Are you a Radio Communication Expert? Answer questions, earn points and help others
