The freezer freezes the food rock hard. There is frost throughout the freezer part. Today I noticed a half inch of ice on the bottom of the freezer. I cannot slide out ...
DSLReports
Jul 31, 2014 - 16 posts - 12 authors
I'm guessing food won't last as long if it's too cold? ... Freezer is too cold? I get a build-up of ice in some of my frozen items in my freezer. .... If no recent changes, then maybe you are seeing only part of the frost build up. Maybe ...
? 1:30
https://www.youtube.com/watch?v=8g_39UHYeEA
Feb 9, 2012 - Uploaded by Dal4us
Our freezer was getting too cold and refrigerator was not cold. ...Refrigerator Repair - Fresh Food Section Is Not Cooling , Kenmore , Whirlpool ...
As long as the impedance of the speakers do NOT go below the rating of the amp you can connect them without worry Your amp would drive two 8 ohm speakers. Using the 16 ohm speaker it will only draw half the current and only accept half the power that one of the 8 ohm outputs can deliver.
The answer all depends on the impedance of your speaker(s). A single speaker can be plugged into either jack. Set the switch to the impedance of your speaker. If you use two speakers, set the switch to one half of the impedance of the lowest impedance speaker. Very few speakers are 16 ohm types. Most are 8 ohms and some are 4 ohms. You could plug an 8 ohm into each of the jacks and set the switch to 4 ohms for example.
Since this is a custom install and the wires don't follow a rule the only way to find which is which is to disconnect all the remaining speakers, plug in light bulbs in their places and check every single pair till they all match and their corresponding bulb lights up.
There is most likelt a channel not working in either the receiver or amplifier depending upon what equipment you own. Could you update this with a list of the equipment in the system?
Thanks,
Dan
