Fault to the main power supply regulator section. Either it will be a separate board, or the part of main board. Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
It will be best to replace the power supply regulator board as card basis rather than making "Surgery" to it; which usually will make loss for both money and time. Even though you can make it right, it will cost around an amount equal to the cost of a new board; including the cost of (spare parts + service charge) More to say, most of the spare parts to it will be difficult to get from open electronic spare part market. This is true to most of the flat panel TV power supply boards; irrespective of its brand and screen size.
SOURCE: Vizio VW42LFHDTV10A
I give you a site for do it your self repair..
http://www.lcd-television-repair.com/
SOURCE: only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
SOURCE: TLA-04011c 40in. LCD TV: Red light is on. TV
I have the same TV and I just replaced the Capacitors. It came with 2 10000UF 10V caps and I put in 2 1000UF 35Volt caps from radio shack. Its like brand new. There is even a video on how to change them on You Tube.
SOURCE: my Vizio vx32L isnt getting power. the orange
I had the same problem after having a Vizio for 2 and a half years. I
left the room for a minute, i came back and the screen went black.
There was still power to the unit and you could see that the back light
was working, just no picture, no sound, and you couldn't use any of the
buttons. The only way to turn it off was to unplug it. It would then
start up, with the Vizio logo going from orange to white, and then do
the same thing all over, no pic or sound.
HOW I FIXED MINE:Look through the back vents for a white light to make sure the backlight still works. I ordered a new "main PCB" from tigerdirectparts.com
(you can also use searspartsdirect.com). This is the circuit board with
all of the inputs on it (hdmi, cable, etc.) I opened it up,
disconnected the old one, put in a new one and now it works fine. I used
both serial numbers on the board to search for it online. It cost me
$144 to do it, but that's better than $450 for a new TV. My tv is the
vx32l hdtv10a. I hope that helps.
For me the part number was either (depending on the vendor) : 0171 2272
2174 or it was 3632 0212 0150. Check your circuit and see if any of
those numbers match up.
