Briggs & Stratton Lawn-Boy Insight Series 21-Inch 190cc  650 Series Gas Powered Engine Variable Speed Self-Propelled Lawn Mower Logo
J
Jerry Vollin Posted on Jan 25, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Engine will not run unless i prim it & keep priming it . help please jerry
Bill Boyd
Level 3:
Top Expert:
  • Briggs & Str... Master 53,816 Answers
  • Posted on Jan 25, 2016
Bill Boyd
Level 3:
Top Expert:
Answers
53816
Questions
7
Helped
11931534
Points
172802
Check for a blocked main jet in the carby or blocked fuel line to the carby
05 jeep won't start after running outa gas and putting more in ...
There could be a couple of reasons for this.
But that’s not to say it’s a big problem.
1st, make sure there is enough fuel in it.
Some vehicles with a large fuel tank, won’t pick up when there’s only a small amount. So stick another Jerry cans worth in if you can.
Secondly, put a battery pack / jump pack or cables on it to give it a power boost and keep cranking it. It can take a while for the fuel pump to get the fuel back to the engine and fill the fuel lines.
Also, keep “priming” the fuel pump.
* put the keys in the ignition, turn to position 2 so the car is ready to start and all the lights are on the dash, wait 10 seconds, then remove the keys, and repeat this process 2 or 3 times before trying to start”
This will get the fuel pump to prime up and push fuel down the lines.
Kind regards, Rickey.
If this helps, please click helpful!
Have a swisher trim and mow model st67522e will not start unless I spray primer in carburetor. Already cleaned carburetor. Runs once primed but will not start when shut down . Have to prim again to get...
Check the fuel jet and make sure it is clean. If there is any dirt in it even though you cleaned the carb the unit will not run properly if any at all. I use an air compressor to clean mine ore a real fine piece of wire.
Primer does;nt work. Engine will not start until manually primed. Tjhen starts on first pull. Do I need a new primer? How do I do this. Engine is a 12H882 from 1996.
-Every small engine that comes with the prim Bold. You need to prim (Press) couple time before start. This is normal and always.
-You say you have to prim before it can start. This is normal.
Your machine is good. No need to replace any thing.
Good luck and enjoy it
Mai
May 18, 2017 • Garden
If the fuel pump is bad on a 2000 ford expedition. will you still hear it prim up?
I think the priming is just the pump running on a short timer. Doesn't mean fuel is getting to the engine, or that it is even pumping.
Volkswagen Golf Cars & Trucks Fuel pump prime
Do not prime a gas engine-- if that is what it is
Fuel is under pump pressure & any air is blown
into cylinders on start up
I have titan 440i and it has very low pressure when i swich it from prim to spray keeps running
When you switch it from prime to paint and it's still running:
- If paint/water continues to come out of the prime tube, your prime valve isn't seating properly and needs to be replaced.
- If you get a little pressure at the paint gun but it is surging, your packings, most likely the lower set, are damaged and letting most of the paint leak back past them. Packing/seal kits are available for your machine. Use all parts in the kit and grease/lubricate all of the parts well. Inspect the piston and cylinder for scoring or pitting that can damage new seals. They should be mirror smooth for proper operation and life of the seals.
1helpful
Oil level. Checked with engine on or off? How many quarts approx to fill it? Gas petcocks 3 settings. one is on. One is reserve. One is prim? What is prim? What is the spark plug size? 18mm? Special...
1. Oil level is checked with the engine off and the bike on its center stand so that the oil level is even across the engine.
2. Without knowing the model and year of your bike, it's not possible to suggest the oil capacity for your engine. Some engines have the maximum oil capacity molded into the engine case near the oil filler; others do not.
3. Your fuel petcock is vacuum activated. When the engine is running, a small amount of vacuum keeps the fuel flowing when the petcock is set to "On" (main tank) or "reserve" (emergency dregs of the tank). "Prim" stands for "prime," which permits fuel to flow without the presence of engine vacuum. You'd use this if you ran the bike out of gas and needed to get fuel to the carbs so that the engine could be started again. You don't want to keep your petcock set to "prime" for very long when the bike is turned off (or even when it's on) so that the carbs can't overfill. In extreme cases, you can fill your crankcase with gasoline, which can lead to hydraulic lock and the potential for serious engine damage if you try to run your bike like that (I've had that happen to me).
4. Again, without knowing the year and model of your bike, I am not able to provide any information about the spark plugs used by your bike. However, if your bike has 18mm spark plugs, you'll need an 18mm deep socket to install and remove them. I recommend using a 6-point over a 12-point socket for this purpose--and spending the extra dollar or two to get a good quality, brand name socket. I have never seen an 18mm "spark plug" socket, but if you're really concerned, you can take the little rubber insulator out of an old spark plug socket and stuff it in an 18mm deep socket. I have never bothered.
1helpful
2answers
To clarify my problem.... My 99 Chevy Silverado ran out of gas one day. As you know when this happens it sometimes toast the fuel pump... So i did have to replace the feul pump. It was a junkyard fuel pump...
It sounds like the fuel pressure check valve on the fuel pump has gone bad and your losing fuel pressure when engine is turned off. Try priming the fuel pressure twice, that's when you turn the ignition keys to the run position with out starting the engine for 10 seconds and then turning the key's to the off position and on again for 5 seconds. After the second prim the engine should start, to check this you can lone out a fuel pressure gauge and check the fuel pressure at the shredder valve. You should have 62 to 65 PSI during prim and once the engine is running, it should drop by 5 psi. As for your the accuracy on reading the right amount of fuel in your gas tank, the sensor is apart of the fuel pump sending unit and the float may have gotten bent and nothing you can do to fix it unless you take the fuel pump out again and replace the sending unit. Good luck and keep me posted.
2answers
1997 jimmy 4.3 liter hard start. Have to prime throttle body when
could be your battery is getting old they tend to lose performance in colder weather.
Top Briggs & Stratton Garden Experts
Jay Finke
Jay Finke
john h
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
