Toshiba 62HM196 62" SD Television Logo
g
grover crossland Posted on Jan 24, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Toshiba rear projection will not play one antenna channel
When selecting an antenna channel it will automatically turn off and back on again and again only on the NBC channel
Claude Kayser
Level 3:
Top Expert:
  • Toshiba Master 9,098 Answers
  • Posted on Jan 24, 2016
Claude Kayser
Toshiba Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067127
Points
28436
How To: TV Auto Program / Channel Scan - TOSHIBA FORUMS
forums.toshiba.com/t5/Televisions...Base/...Channel-Scan/ta.../345660
Aug 7, 2013 - The following article will take you through the procedure to perform achannel ... TOSHIBA television to store channels from a cable TV or TV antennasignal. ... The TV must not be connected to a cable box through the coax ... The Option 1 procedure is for TVs with menus similar to the one shown below. Understanding / Changing Inputs on your TV
Mar 9, 2012
46G300U Intermittent Flickering / Flashing / Pulsa...
Sep 22, 2011
new tv.... dolby digital not working through optic...
Sep 19, 2011
More results from forums.toshiba.com
Missing: rear
[PDF]User's Manual - Newegg.com
images10.newegg.com/User-Manual/User_Manual_24-207-007.pdf
High Definition TV broadcast, a High Definition digital cable program, or a High Definition digital satellite program). For details, please contact your TV antenna installer or your .... 14a) Item 14 does not apply to "Lamp unit replacement and ...... Thank you for purchasing this Toshiba TV, one of the most innovative DLP™ ...
Toshiba 52HM84 DLP Rear Projection Product Review and ...
? 10:43
https://www.youtube.com/watch?v=B4VRJPUmpho
Nov 3, 2012 - Uploaded by Channel 2012
In one of my very last videos before my old account was spontaneously shut down, I covered a decent 52" DLP ...
How do i turn off the closed caption on my toshiba 51h84 tv? i tried setting via the remote and changed the CC option to OFF but i still see the closed caption wording...it is driving me crazy!! help!
What is the source of your TV signal: Cable? Dish Networks? DirectTV? Antenna?
Many times the Cable/Dish Networks/DirectTV controller also has an option for closed captioning. Please verify that a controller is not setup to deliver the CC data.
Also, try setting the TV CC using 'C1' or 'T1' and selecting 'Enter' to accept the change; then come back and set CC to 'Off' again to see if toggling on/off helps.
Digital channels antenna
If you have a HD TV then you do not need a converter box, however you will still need an antennae to receive the channels. the antennae can be hooked up directly to you're HD tv.
How do i set my Toshiba ct-90157 remote to watch dvd's
Most DVD players are connected to one of the rear audio/video inputs--hook to that input and select it on the TV--then hit play and if connected correctly you will see the movie.
2answers
In just bought new Toshiba regza 40" Lcd tv and auto tuned it, but the picture is terible , snowy and colours are not good, what to do...
Hello
First of all reset the TV. for that
press and hold the POWER button
on the TV control panel for 5 or more seconds to reset the TV.
Then connect the TV tt any source like outdoor areiel or cable box etc, select the appropriate input, and retune the TV. First of all, connect it to an external antenna, and set it to autotune.
You must configure the ANT/CABLE input source before
programming channels (-left-hand column).
If the ANT/CABLE input signal type is set to Cable, the
automatic channel programming process erases channels
that were previously programmed into the TV's memory.
If the ANT/CABLE input signal type is set to Antenna, the
automatic channel programming process adds newly found
channels to the existing set of programmed channels (and
does NOT erase channels that were previously
programmed into the TV's memory.) To remove an Antenna
source channel from the memory, you must manually delete
it.
To tune the TV to a channel not programmed in the channel
memory, you must use the Channel Number buttons on the
remote control.
Programming channels when the ANT/CABLE input is
configured for Cable will take substantially longer than when
the antenna input is configured for Antenna. This is normal;
however, once channel programming is finished, you should
not have to repeat the programming process again unless
your Cable TV service lineup changes significantly.
Find out the received channels are clear or not. If they are clear, your TV is perfect, and the input device you connects ot the TV is faulty. OK.
Need to retune free view as has never been done since buying
Hello
To retune your Lg tv, do the following. At first connect the antenna socket at its back side with antenna firmly.
hannel Search
Automatically finds all channels available through antenna or cable inputs, and stores them in memory on the channel list.
- Run EZ Scan again after any Antenna/Cable connection changes.
- A password is required to gain access to EZ Scan menu if the Lock System is turned on.
1. Press the MENU button and then use UP/DOWN button to select the SETUP menu.
2. Press the FORWARD => button and then use UP/DOWN button to select EZ Scan.
3. Press the ENTER button to begin the channel search.
Allow EZ Scan to complete the channel search cycle for ANTENNA, and CABLE
ok.
1helpful
Just got an antenna to pick up local HDTV channels. I scan the channels and none are found. does it matter if I connect to "Ant1" or "Ant2"? neither seem to work. Thanks.
According to the user's manual on page 16, press Menu and open the Setup menu. Highlight Installation and press Enter. Open the Terrestrial menu and highlight Input Configuration. Select the ANT1 or ANT2 (whichever the antenna is connected to) and select input source Antenna [not cable]. Highlight Done and press enter. Now rescan your channels. If you still get nothing, try relocating your antenna to a better place. Digital TV is highly dependent on line of site signals. So if you are in a mountainous region or surrounded by a lot of high rise buildings, you may not receive a good enough signal to register channels on your TV.
2answers
Tune playstation 3 to toshiba television
first try to manuall select your av channell from your tv's remote control,if this won't work try another scart cable or port on your tv set
2answers
Thomson scenium rear projector 52inch
What is your tuner source? Cable, Satellite, or antenna?...accordianman
Top Toshiba Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
