Power the amp on but get no sound blue light comes on just as it should and everything hooked up correctly?
SOURCE: Power screw stripped for JBL Car AMP GTO 75.4 II
Actually I buy them in lots of 1000 and I pay 38 cents each for them. They are 24k gold plated. They are the real deal. If you do the math you can see I do not make much of a profit at all on them.
Regards
AmplifierScrews.com
SOURCE: JBL GTO 301.1ii protect mode
Hello roets81,
Check the voltage at the amp. It's possible that the voltage is either too high (above 16V) or too low (below 8.5V). Also make sure that the amp case is not grounded. If these check out OK, the most likely cause is that the amp itself is defective and requires service.
Hope this helps.
SOURCE: jbl am in protect mode
if it goes in protect mode means ur amp is turn up to high or it is over heating so it protectn it from fryn ur amp try to adjust it down
SOURCE: JBL amp, worked fine untill 2 days ago. protection light on..
might have roasted your speakers voice coils a little which may be sending the amp into protect mode throw a speaker on it that you know works and if it doesnt trigger the protect circuit then you probably have a blown or almost sub.
Cmon someone throw somethin out there
