Al Bond Posted on Jan 24, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Konica minolta bizhub c203 blue data light blink copier not working
Norman Weimar
Level 3:
  • Konica Minolta Master 7,035 Answers
  • Posted on Jan 25, 2016
Norman Weimar
Level 3:
Answers
7035
Questions
Helped
1912000
Points
11959
Have you cleared all the print jobs currently in the que and on the control panel. also disconnect your network cable power off the machine then on will it copy not print? data light blinking mean job is trying to run is the paper draw or by pass tray have paper an in the correct orientation landscape or portriat
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/normanj_7893313f0751935f
Please how can I clear the memory on my printer (Konica Minolta bizhub C203 coloured printer)
Go to service mode
utility-counter-stop-00-stop01
go to system 2/ or 1
select initialization.
select all data.
press start button
restart from main power.
Re-configure all network setting for printing/scanning
When trying to scan to email from Konica Minolta C203 we get an error message "From Address not set, unable to Transmit, please specify From Address" any ideas.
need to create a from address in the copier either bye at the op panel or thur pagescope look up a you tube video how to set up to scan to email with a bizhub c203 or any bizhub 3 series
RE Konica Minolta bizhub C203 - C-D403 fault. Please advise
its a check sum error.... please give me more info... is it working or does it do it when printing huge docs......? more info please
My konica minolta bizhub c203 will not send out faxes ng error code
you cannot have a VOIP line or FOIP line (like comcast or Vanige) it can only use a dedicated land line. i know this is aggrivating...
What software do i need to scan through a PC?
GO THOUGH WEB BROWSER ONLY THING YOU HAVE TO DO SET UP IP ADDRESS, DOWNLOAD DRIVER FROM KONICA/MINOLTA FOR BIZHUB C203 THEN WEB BROWSE TO SET UP SCANNER SOFTWARE ALREADY THERE.
1helpful
The print margins on my Konica Minolta Bizhub c203 cut off the bottom of my pages. how can I fix this?
Check and see if it does it on copies too. If so then your paper trays maybe out of center or your paper guides may be open. If everything is center and registration is correct, your print may be in the "Void Margin" this is an area around the page the machine will not put toner in. Konica Minolta Bizhub C203 copiers do not have an edge to edge print capability
Top Konica Minolta Office Equipment & Supplies Experts
Norman Weimar
Norman Weimar
ZJ Limited
ZJ Limited
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
