If you have the correct size die you can rethread it. If not.
Turn off water remove old faucet and replace
turn on water and check for leaks.
Hope the helps Mike
Note: You may also take a razor knife
start at the top of the threads (near handle) and spin around and down to open the threads again. BE CAREFUL Then do this again with a small flathead to open them wider and slowly connect a known good hose end on and off several times
