SOURCE: I removed the oven door
Take the door back off and try again. The hinge is not in the receptical all the way
SOURCE: My 36" 6 burner gas
You could of used to much oil on the hinges most likely though the hinges are not seated properly though. Have you assured that the hinges are in the correct position? Also what was the original problem that you found with the unit when the door was stuck in the open position? And how did you correct this as well? There are positioned seatings in the hinge that cause the door to be able to be positioned at the 30 and 45 degrees if you also have to much lubricant on the seating then the hinge would glide right past the 30 and 45 degrees stop points. If you have any further questions message me back. I await your reply to the questions that I asked Thanks Rick
SOURCE: How do I remove the door to my Jenn-Air wall oven
Hello, marslyn
I was trying to help
you out here. Maybe this will help some? I was going back to some customers that asked questions
in the recent past and farther back, It appeared that no one answered some of them, So, I thought I
would take some of my personal time to see if I can help. Even though
this site may not have your exact model or brand, This link will help
you tons. Here is a link
to about everything you want to know about your oven, from repair
to trouble shooting it. Even pictures and video's. Just scroll around
and you
will see tons of information to almost any question you might have on
your Oven. If you go to this link and click around, I am sure you
will find out so much about your oven, you will know more than the
company that made it. The good thing about this link is, then you can
make the decision of DIY or hiring a pro. Here Is the link for you to
click on>>
http://home.howstuffworks.com/dishwasher.htm
Please if this helped you at all, if you can find the time
to rate my help and some kind words written would be appreciated for my
free help , I would appreciate it. Here is also my direct link to my own
pages of other areas of my expertise for other problems you might have
in Automotive,Appliance, and Electronics. Drop In anytime for my help.
Thanks,Mike
http://home.howstuffworks.com/how-to-repair-an-oven.htm
Thanks,Mike
http://beta.fixya.com/users/mc1bean
SOURCE: dhow do i remove stoves efa600H oven door hinges?
1. Open the oven door and remove the 2 screws at the side of the inner glass window 11cm above the hinges and lift off the door. Place it somewhere safe!
2. Remove the 4 screws that you can see nearest to the left and right edges of the oven with the door removed. These secure the oven to the kitchen unit.
3. Slide the oven forwards about 20cm out of the unit, being careful not to pull on the cable.
4. Each hinge is held in place by 2 screws at the side of the unit now exposed, about 18cm apart. Remove them and slide out the hinges. Reassembly is the reverse of the above.
5. Note that the hinges have no means of adjustment. If not working properly, renew them.
