Question about Samsung Audio Players & Recorders
How to connect a Panasonic SA PT950 home theater syst. to a Samsung flat TV UN65JU650D?
I connected the Samsung HDMI (ARC) to the HTS HDMI connector without any luck. Duke
    Top Expert:
  • Samsung Master
  • 9,098 Answers
Samsung 40'' 720p tv and Panasonic home theatre system ...
? 5:30
https://www.youtube.com/watch?v=zDG-PZtqCNE
Jan 4, 2012 - Uploaded by Nazil Rahman
Samsung 40'' 720p tv and Panasonic home theatre system ...How to Connect an HDTV to Your Sound ...
New way to connect TV to Surround sound using HDMI ARC ...
? 4:46
https://www.youtube.com/watch?v=fFNEKnlQd6I
Dec 13, 2013 - Uploaded by Tampatec
How to Connect TV to Surround sound receiver system setupusing HDMI ... to Samsung, LG, Sony, Vizio ...
Unable to connect Samsung smart TV with Panasonic home ...
www.tomsguide.com/.../unable-connect-samsung-smart-panasonic-home...
Dec 16, 2014 - hi I bought Panasonic SC-BTT405 blue ray disk 5.1 home theater and ... Unable to connect Samsung smart TV with Panasonic home theater ... I have an LG55LA9650 smart TV hooked up to a Bose 3-2-1 home theater system.
Posted on Jan 23, 2016
  • Samsung Master
  • 4,277 Answers
How to Recover Lost data from Samsung
For restoring data from Android device, Android data recovery is the ideal program you need, what an excellent tool enables you to recover lost data from Samsung. It allows users to restore deleted data for any types of Android data, including messages, photos, contacts, call logs, videos, WhatsApp messages, and more.
It can help to perform the data recovery under any data loss cases, like accidental deletion, Android OS crashes, Android ROM flashing, broken screen, factory reset restoring. It supports Android device of any brands: Samsung, LG, Sony, Google, OnePlus, ZTE, OPPO, etc,. Restore lost Samsung file as explained below. There are six steps as shown in the follow section.
LEARN MORE
Android Data Recovery Software
How to recover lost deleted WhatsApp Message from Samsung galaxy Note 9
How to recover lost deleted call logs from Samsung galaxy Note 9
How to recover lost deleted video from Samsung galaxy Note 9
How to recover lost deleted files from Samsung galaxy Note 9
Posted on Nov 08, 2018
SOURCE:
I have a Sony bluray surround sound and lg smart tv, I can't play my Apple TV sound through my hts, all my connections are hdmi and both systems have arc, please help?
Is your Apple TV connected to the Sony or directly to your TV? If directly connected to the Sony HTS ARC shouldn't be needed and you should have audio. If that's the case check the Apple TV settings to be sure it isn't set for s/pdif output. If connected to the TV then the TV should be able to put a s/pdif signal on the HDMI ARC pin but perhaps there's no way to assign it to the HDMI input coming from the HTS? It may be going to the ARC pin on the Apple TV HDMI input which won't give you any sound. Normally ARC is intended to put the s/pdif signal from the TV's internal tuner on the HDMI cable from the HTS so the HTS can play TV sound without having to tun a separate Toslink cable from the TV s/pdif output to the HTS. One other thing: Early HDMI cables do not include the ARC wire so be sure you have ARC capable cables. Look in your TV documentation to see if there is a way to assign the ARC output to a different incoming HDMI input if the Apple TV is connected directly to the TV. If not you may need to resort to a Toslink optical cable from your TV to an optical input on your HTS. Or actually running that cable from Apple TV to the HTS would be better since it's possible it could carry surround sound. Most TV's optical outputs are limited to the 2 channel sound the TV can accept.
Oct 22, 2014 | Audio Players & Recorders
I need a manual for a panasonic sa-pt950
The Panasonic website should have a free PDF of it!
Mar 24, 2013 | Panasonic Sa-pt950 Receiver Only For...
Samsung tv to panasonic sa bt100 home theatre
it is the problem with the hdmi cable .. dont buy cheaper cables it may damage after some time
Aug 24, 2012 | Audio Players & Recorders
How can I hook up a panasonic home theater to my brand new LG lcd tv?
Your TV must have an HDMI connector. Please check if your home theater also has an HDMI connector - like this one:
If so, then all you need to do is buy an HDMI cable, and connect one end to your home theater, and the other to your TV. HDMI cables have a digital connection that carries both audio and video, so they are quite convenient. Don't forget to select the HDMI input using your TV's remote control.
Tip: HDMI uses a digital transmission scheme which is fairly robust (unlike analog transmissions), so a $5 HDMI cable will perform just as good as a $50 or $100 HDMI cable. Don't let those store clerks rip you off.
If your home theater does not have an HDMI output, then you must use the analog connections. Look at the back of your home theater and make note of the connectors labeled as 'Output' (both audio and video). You should buy cables with connectors matching those connections.
If you need more clarification on this subject, just ask.
Mar 02, 2011 | Panasonic Audio Players & Recorders
Playstation 3 hook up problem
I ended up using the component in cable hookup and fiber optic digital audio instead of HDMI - works fine.
Dec 28, 2008 | Sony Playstation 3 (PS3) Console
No HDMI output with Panasonic SC-PT950
Change the video out settings from your system
Dec 10, 2008 | Sony DAV-S400 System
PANASONIC HOMETHEATER SYSTEM TO PLASMA TV
Some where on the back, bottom or sides of your plasma tv you will find input jacks for the audio and video. You must know what type of inputs you want to use.
Most have have 4 types
HDMI (audio and video signal combined)
Component (red, blue, green RCA jacks for video only)
Composite (yellow RCA jack for video only)
S-video ( larger round black jack with video only)
The Panasonic should have all of those also. I am certain it has HDMI and Component.
Connect the HDMI cable into the output HDMI jack from the Panasonic into the HDMI input jack on the TV.
Then using your remote for the TV make sure you select the HDMI input for viewing.
If you use any of the other video outputs on the Panasonic just connect it to the same type of input jack on the TV. Once again check the owners manual for more detailed instruction if you need them.
You must always be sure to have the proper input selected on the TV to be able to view it.
You can also respond back with more questions if you have any.
I am happy to help.
Dave
Jun 27, 2008 | Audio Players & Recorders
Hooking up home theater
Run a regular RCA type audio cable from your TV audio out to your Home Theatre audio in. That is what I have done recently with my Samsung LCD and Home Theater. You then have to put your Home Theater on Aux 1 or Aux 2 to get the sound from TV. Ensure your TV's volume is off.
Kurtis
Nov 04, 2007 | Audio Players & Recorders
1,192 people viewed this question
Top Samsung Audio Players & Recorders Experts
Mike Duncan
Mike Duncan
Marvin
Marvin
Are you a Samsung Audio Player and Recorder Expert? Answer questions, earn points and help others
