Lenovo A399 Mtk6582m Quad Core Cell Phones 512mb RAM 4gb ROM 5.0& IPS Dual Sim Android 4.4 Wcdma Wifi white Logo
Tony Watkins Posted on Jan 23, 2016
Hi i have a brand new lenovo A399 i can not answer the phone when i press the icon it will not do anything and keep missing calls
1 Related Answer
Seekoo
  • 35 Answers
  • Posted on Feb 27, 2016
SOURCE: my lenovo A399 mobile phone and its going onto the start up screen but wont boot up so i plugged it into my computer and its coming up error code 28
Is the battery removable ?
Phone stuck will not allow use.
Backup All Your Data (pics, contacts,music etc) before doing it.
*2767*3855# Dial this after backup n let the phone to restart itself.
Error code 0000 when i run diagnostic on lenovo x100e thinkpad its a brand new. What will i do?
Please view the following website. Here you should find the answer you are looking for. It sounds like you are missing a driver.
http://download.lenovo.com/lenovo/content/ddfm/MIGR-74463.html
Please let me know if you need further assistance.
carsandcomps,
Guru, Premium Expert @ Fixya.com
My Vtech 5.8GHZ phone lists all answered calls as 'missed calls'
The phone will keep in cronological order, all calls received. The last 20 or 30. Dont think you can choose which ones it lists.
1helpful
Need set-up Information for Blue Tooth phone in Chrysler Pacifia 2005
I found the link below containing a download of the .pdf file and also pasted the phone pairing portion below it. These instructions are exactly the same as when pairing to my system in my '08 Caliber,so they're probably universal. Keep in mind, though, that the system just may not be fully compatible with your phone. EVERYTHING that Chrysler makes is EXTREMELY finicky-and you may be doing everything right! Before you begin, set your phone into its pairing or "find me" mode, then press the UConnect button. I hope this helps! Good luck.
http://dcxtraining1.com/dcxtraining1/docs/ExperienceFreedom_UConnect.pdf
Linking to UConnect – Required for First-time Use of Each Mobile Phone
To complete the pairing process, the mobile-phone owner’s manual will need to be referenced. One of the following vehicle-specific Web sites will also provide detailed instructions for pairing with the phone: www.chrysler.com/uconnect, www.dodge.com/uconnect and www.jeep.com/uconnect.
• Press the Phone icon button to begin
• After the Ready prompt and subsequent beep, say Set Up Phone Pairing
• When prompted, after the voice or beep, say Pair a Phone
• You will be asked to say a four-digit PIN that will be needed later to enter into your mobile phone. You can use any four-digit PIN. You will not need to remember the PIN after the initial pairing process
• For identification purposes, you will be prompted to give the UConnect system a name for your mobile phone. Each mobile phone that is being paired should be given a unique phone name
• You then will be asked to give your mobile phone a priority level between one and seven, one being highest priority. The priority allows the UConnect system to know which mobile phone to use if multiple mobile phones are in the vehicle at the same time
Making a Phone Call
• After the Ready prompt, say Dial
• The system will prompt you to say the number you wish to dial
Making a Phone Call Using Your UConnect Phonebook
• After the Ready prompt, say Call followed by the name and designation of a phonebook entry you wish to dial – for example Call, then John Doe, then Work
Terminating a Phone Call
To end a call in progress, press the Phone icon button. All calls in progress will
be terminated.
Phone Redial
• After the Ready prompt, say Redial
• The UConnect system will call the last number that was dialed on your mobile phone. This may not be the last number dialed by the UConnect system
Answering or Rejecting an Incoming Call - No Call Currently in Progress
When you receive a call on your mobile phone, the UConnect system will interrupt the stereo audio to ask if you would like to answer the call. Press the Phone icon button to answer the call. To reject the call, press the Phone icon button until you hear a single beep indicating that the incoming call was rejected.
UCONNECT
CHRYSLER GROUP TECHNOLOGY 17
How can i turn on the answer phone and reduce the number of rings till it switches on
when any call come 2 ur phone then press green key 2 ur mobile which icon of pick up. and for solve another problem then send me ur phone brand and model no
4helpful
Deleting missed call symbol
Hi you go to your answer button with is the green phone thingy. you press it ,as it opens it will show you the missed calls ,press on the missed call you received then you'll have the open button option. Just open it and the missed call red arrow ,should dissapear.
Dec 02, 2008 • Cell Phones
6helpful
3answers
Motorola KRZR K1 not showing missed calls
I had the same problem on my K1, and I fix it like this:
- Insert a new SIM card into your phone (borrow it from someone you know)
- Start the phone.
- Type in some number then ring it (press on green button)
- Now when you press green button the phone should show recent calls
- Switch off phone, insert your sim card, switch on, press green call button
- The recent calls will be empty but there
This one solve my problem with recent calls.
Cheers
Top Lenovo Cell Phones Experts
ADMIN Andrew
ADMIN Andrew
john h
Are you a Lenovo Cell Phone Expert? Answer questions, earn points and help others
