I have a WF100 hotpoint washing machine, the wash had finished and the door lock light off but the door will not open, i have tried re-running the wash and unplugging it and still it is locked please help i need to empty it asap
The interlock has jammed, first try gently pushing the door frame on the latch side of the door and then hit the outer door frame with your fist, not too hard but a reasonable bang this may release the door, if this works spray a lubricant into the latch hole in the panel, open and close the door a few times before reusing, if this fails then you have to force the door open, the best way is to remove the lid and manouver the door lock from the inside, either the lock or the latck will eventually break, this is unavoidable, then replace the interlock and any other broken part.
Regards
Advisor
Thank you, i tried your first solution with no luck, is there no other way than breaking it?
door not opening after wash cycle finished
