Televison & Video Logo
Michele Ishmael Posted on Jan 23, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
My 60 inch Mitz keeps blowing bulbs - Televison & Video
Ron F
Level 2:
Novelist:
  • Expert 135 Answers
  • Posted on Jan 23, 2016
Ron F
Expert
Level 2:
Novelist:
Answers
135
Questions
0
Helped
46756
Points
303
I have to assume you are referring to a projection TV when you say bulbs. With that in mind, the lamps do run hot so you want to make sure the TV has adequate ventilation around the TV grilles first. Next you want to make sure the lamp fan(s) are clean and no dust blocks the fan or cabinet openings the fan draws air from. That takes care of air circulation. The lamp itself has a relatively short life span of 2 to 3 years, I can't remember the hour rating off-hand. I have seen some last a year or just under but that's usually for high viewing times like 12 hours a day more than likely. Beyond that, the lamp ballast (power supply) could be an issue but it's less likely.
If you are changing your own lamps, make sure you don't touch the lamp with your fingers as the oils can from you skin can shorten the life of it just like it does with any quartz bulb, like halogen bulbs.
1helpful
No batteries that I put in it will keep it on and the lens goes in and out and then won't go all the way back in when it goes off.
this is due to dust or moisture if you take this type of cameras near seashore this happens. keep it near 60 w bulb for 1 hour and then blow the dust particals with help of blower
Why am I blowing my Bulbs?
Replace the bulb power driver.
1helpful
I have a 60 inch LG t.v. that needs a new bulb
The part number for the lamp is: 6912V00006C
It can be purchased from tritronicsinc.com for $199.00 plus shipping.
Dan
2helpful
2answers
My sony wega 60 inch tv will not turn on. The
I bought a new blub for it and the light still goes green then red.Anybody know?? mg
No picture and buzzing sound on Sony XBR Wega
Is the bulb light flashing ? - Sony's bulb light is very accurate in telling you if the bulb is bad. The buzzing sound could be from the balist trying to strike the lamp. You also may want to open the lamp door and see if the bulb is shattered.
Nad 218 thx power amp keeps blowing ac plug fuse
Hi there. From memory they had bridge rectifier problems with them going short circuit. Check them first. Sometimes the toroidal transformer can go a shorted turn, in turn blowing primary fuses. try to soft start it whilst it is blowing fuses, Best bet is to make up a special lead that has a 60w light bulb wired in series with the mains power supply(or across the fuse holdwer that is blowing:). Limits the power in the circuit to ... well you guessed it 60 watts.
check em out and let me know.
regards
Graeme
Picture turns red and blue color after television has warmed up
sounds like u are losing green? is that right. could be loose connections somewhere because it works at start up then fails when it heats up. Look in the yellow pages for a mitz auth servicer or call mitsubishi for one near u.
2answers
Tv cuts off and green light flashes
the tv will try to reboot a few times. just let i try and eventually it will start blinking red. if you could count the red blinks then i can further assist you.
Top Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
 Grubhead
Grubhead
