As said I get the fan fail error, but I think it might be a systematical problem, wondering if anyone has ever experienced it and how it might be fixed.
Fans have 3 wires, power (red), ground (black) and third is RPM. If the fans internal RPM sensor isn't providing the speed reading to the electronics it thinks the fan stopped initiating an error shutdown process. You could possibly try an outboarded fan with the same wiring and voltage to see if that makes any change but if replacing the fan with an OEM fan doesn't fix it, then you have a board issue or wiring failure if the fan doesn't plug directly into the board.
Make sure you check every fan in the unit.
