Sylvania LC420SS8 LCD TV Logo
J
Juan Mercado Mendez Posted on Jan 22, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
RESISTAN VALUE OF R522,R524 ON THE INVERTER BOARD BA71F0F01041.
George
Level 2:
Habit-Forming:
  • Expert 132 Answers
  • Posted on Jan 22, 2016
George
Expert
Level 2:
Habit-Forming:
Answers
132
Questions
0
Helped
28070
Points
436
Hi Juan,
the resistor values you want are:
R52
RES METALIZED FILM T 1/4W F 3.92k?
R524
CARBON RES. 1/4W J 10k?
The complete Service Manual is available as a .pdf Here:
Sylvania LC420SS8 LCD TV Service Manual
Its free to view, but you'll have to agree to a free 14 day trial membership to download it. Hope this helps you,
Testimonial: "THE RESISTORS I"M LOOKING FOR ARE FROM A SILVANIA LC320SS8 INVERTER PCB. BUT THANKYOU VERYMUCH."
1helpful
R522,R524,RESISTAN VALUE ON THEINVERTERBOARD.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience.
http://electro-medical.blogspot.com/
Circuit diagrams of many popular brand devices are given. Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Turn on - flashes logo - then black screen with audio and channel changing capability
Back - light problem. Check and replace damaged component/s at its back-light inverter board, or replace this board as card basis. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. It will be best to replace the inverter board as card basis.
To some model sets; especially LED back-lighted types; the back-light inverter circuit will be part of the main power supply board [SMPS]. In such cases, the power supply board might need replacement.
8helpful
3answers
Where is the inverter board located on the element flx-3210? Is it somehow combined with the powersupply? I've taken the TV apart and have found everything except a part that resembles an inverter...
Yes, inverter circuitry is combined in one board together with the power supply circuitry. It is beside the connectors of the power supply board to the mainboard. You can see two high voltage transformers, these are the one producing high voltage feeding the bulbs...
There is audio but no picture
Hello!!!
Your problem is caused by the bad Inverter board. Inverter board is the one that responsible for the back-light which is causing by not having a picture...If you don't have a back-light your TV it is of course no picture but everything is good specially the sounds.. The best you can do is to do the following: ...First is to open the back part of your tv so that it could open. ...then find/look for the inverter board.If you are not familiar with it you can find it on the you tube by typing "how to replace inverter board". ...then Just replace the inverter board with the same type & value to fix your problem...
I hope this information will be helpful...If you have any clarification or other query just add a comment.. Thanks for using fixya..
2answers
I have an HP Pavillion DV4 laptop, when turned on the screen displays nothing. Ive been using my laptop by means of an external monitor.
You might have either a faulty LCD cable or screen inverter board.
The LCD cable transfers data signal from the motherboard & video card to the LCD screen. It also supplies high voltage DC power to the screen inverter board. The screen inverter board works as a power supply for the backlight lamp mounted inside the LCD screen. It converts low voltage DC power to high voltage AC power needed for the backlight lamp.
2answers
RCA LCD TV INVERTER BOARD
I have a new power/inverter board for a L32HD32D RCA 32" flat screen LCD TV. Make offer, 1-907-225-2337 I'll ship it USPS in the box it came in.
LS2HD32 CEG379B CAJAID, CAJA4465 1114363 are some numbers on the package it came in. You might try LPS#1 on the ribbon cables & their video board connection for the LCD by opening the back 4x5" pannel in the middle & clean reinstall them ? That's what fixed my TV, maybe. So I don't need the board now. It's only about a 5 minute job to clean the 2 ribbon cables.
Sincerely Bitdog
Internal problem
but you did not give the model number nor did you give the chassis number
Prima cr-20sb72 tv
start with products to specs or contact support.
http://www.primaamerica.com/support.asp
Top Sylvania Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
matt martin
matt martin
Are you a Sylvania Televison and Video Expert? Answer questions, earn points and help others
