YOU CAN PERFORM A FEW MORE STEPS
Manually delete cookie files in Internet Explorer 6 1. Exit Internet Explorer 6, and then exit any instances of Windows Explorer. 2. Click Start, click Run, type inetcpl.cpl, and then press ENTER. 3. On the General tab, click Delete Cookies in the Internet Properties dialog box, under Temporary Internet Files. 4. In the Delete Files dialog box, click to select the Delete all offline content check box, and then click OK.
RUN DISK CLEANUP
DELETE TEMP FILES
1. Click on Start and then Run.
2. In the text box in the Run window, type %Temp% and click OK. A folder full of files and other folders will appear.
3 All of the folders and files you see in this Temp folder are no longer being used by Windows XP and can safely be deleted.
4. To remove individual folders or files, hold down your Ctrl key while left-clicking on each item you want delete. Release the Ctrl key when you're finished.
5. To delete these items, hit your Delete key or choose File and then Delete from the menu.
6. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens.
7. To remove everything inside the Temp folder, choose Edit and then Select All from the menu. 8. Now that all of the files and folders are selected, hit your Delete key or choose File and then Delete from the menu.
9. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens. 10. After all of the files have been deleted
DELETE PREFETCH
2. In the text box in the Run window, type “Prefetch” and click OK. A folder full of files and other folders will appear.
3 All of the folders and files you see in this Prefetch folder , Remove them.
9. Confirm that you want to delete the files by clicking Yes on the Confirm Multiple File Delete window that opens. 10. After all of the files have been deleted you can close the window and empty your Recycle Bin, permanently removing the files from your PC.
Note: If you are unable to clean up the Prefetch files follow these steps to remove the Prefetcher from the registry residual
Download Revo Uninstaller:
http://www.revouninstaller.com/download/revosetup.exeAND REMOVE UNWANTED PROGRAMS
DOWNLOAD CCLEANER CCleaner can be downloaded from
http://www.ccleaner.com/ AND RUN IT
CREATE A NEW USER ACCOUNT
