Driving back from JHB sudden ly no gears, oil from gear box suddely lossed
Now when i start the car still no gears just a not very loud rrrrrr noise from the gear box can it be that the loss of the gear box oil is all the problem is
Hi.. IN CASE YOU DONT NO THAT A CAR /TRUCK /OR BUS HAS TO COME TO A FULL STOP BEFORE CHANGING GEARS FROM ANY GEAR TO ANY OTHER EVEN STOP.
EVEN AUTO MATIC BOX
THE ONLY ONE YOU CAN CHANGE ON THE GO IS A PRE SELECTOR BOX.
Check the gear box oil level sounds low to me i had a similar problem with a auto box car before and as for your steering it could be a worn steering rack if the oil level is good
Sounds like big end bearing gone and oil would probably be coming from gear box and engine seam and falling on exhaust its sounds like a pretty stuffed motor but everything is fixable depending on how much coin it coast and if its worth it cya Neil
I would say some gear teeth are missing or the bearings are worn, this particular model did suffer gear box troubles, Molyslip Gear Oil treatment will help.
Yes a CV joint could cause it. Look under the car with someone putting it in gear. If any of the shafts are turning it is a joint if not the diff in the transmission is gone. Good luck.
no 4-3 or 3-2 downshift uncontrolled downshifts outside range of kickdown switch poor acceleration from stopped position parking pawl will not engage selector lever does not engage in r or p engine will not start in p or n position smoke in exhaust (fluid loss) fluid loss between torque converter & primary pump howling noise when changing gears (under full load) howling noise which increases as engine rpm increases 1st gear & reverse too loud 3rd gear too loud rattling noise at 1500 rpm in all positions except r light grinding noise in p & n positions rolling noises when driving in reverse vacuum control circuit Vacuum Control Valve (E300D & S350D) Vacuum Amplifier (E300D & S350D)
my good friend I believe the solution I give might be not good for you as to what you state It sounds that you are loosing your automatic gear box. Have you ever changed the oil & filter of your Gear box? If not that was the reason.
Believe it or not there are some problems you should take to the dealer. It never was the gear box, its a defective steering column bushing. That problem had a factory notice and the dealer would have diagnosed it immediately an fixed it free parts +$40.install. Tahoes get that problem.
