His may mean that the Xbox 360 has a hardware problem
Solutions
To resolve the problem, try disconnecting your console's hard drive. Here's how:
Xbox 360 E console
If the problem persists with the hard drive removed, you will have to get the console repaired
If there is no red light around the power button, reattach your hard drive.
If the problem persists only with the hard drive attached, order a new Xbox 360 Hard Drive
I appreciate your post, friend!
From what you have described your Frigidaire dryer is showing a "E68" error code. "E68" usually indicates that one of the keys (buttons) is stuck closed (active). You may enter "Function Test Mode" and perform Key Test to determine which button is at fault. To perform the "Function Test Mode": Press and hold the START and CANCEL button at the same time for 10 seconds. The stuck key should blink. Carefully free the key and perform the test again after proper diagnosis. If button is free but the error code still exists, the electronic control will more than likely need replacing. If you do not have a professional connection, you have the option to visit the manufacturer website to find a service provider in your area. Hope this helps! -Matt
