Question about Mercedes M-class Ml Ml350 Ml500 Ml55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2003 2004 2005
Running lights want to turn on spontaneously with engine off, keys out, and light switch off
Headlights are intermittent at times, and the parking lights will come on with no prompt. Middle of the night and the lights are suddenly on
    Top Expert:
  • Mercedes-Benz Master
  • 14,162 Answers
Posted on Feb 18, 2016
SOURCE:
How to find an electrical disturbance in 1998 ford expedition
Normally this condition is the result of a poor body ground connection. Testing for this can be deceiving. At the static(nothing on) condition, testing can show a good ground. However when a circuit is excited, it has a determined resistance and a set current flow. If the ground connection to this or a branch circuit is loose, corroded, or broken wire. This will allow just enough connection to show as being good, but not good enough to complete the circuit with the required amount of connection when energized.
Nov 30, 2014 | 1998 Ford Expedition
2002 rav4
Ok. If they turn on by them selves. Even at night when the key is removed from the vehicle it may be the day time running light sensor. But with the key out this should not happen. You may have an issue with your security system.
Aug 28, 2014 | 2002 Toyota RAV4
Side marker lamp wont turn off
park-tail-running lights.
the park relay fused.
parks are part of headlights , in that they run at any time
for safety EVEN KEYS in pockets.
so are keys in pocket?
and lights off
then it can be only 2 things.
a welded (my name) relay, (contacts fused is the tech reason)
or the switch is bad.
a voltmeter and 1min work and bam, the answer.
some cars have no relay.
so its the switch.
the schematic is at alldata.com its there, see it and how simple.
on new cars the computer brain, runs this stuff. (vastly more complex)
Jan 23, 2014 | Toyota Cars & Trucks
My headlights on my 1999 Pontiac Grand Prix GTP wont ever turn off. Even when i turn the switch to the "OFF" position. They are only off when the key is not in the ignition. What is wrong?
This is the way they were made, and unfortunately, I know a few times I wanted to turn mine off too. The only other way to keep them off when running the engine at least, Is before starting, to engage the parking brake. Then you can start the car and turn the lights off. Sometimes it's at least useful when you want to park at night with the car running, but not have your lights lighting up the block!
Feb 15, 2011 | 1999 Pontiac Grand Prix
UNDERCOVER VEHICLE NEED TO TURN HEADLIGHTS OFF WHEN MOTOR IS RUNNING WHEN SURVEILLANCE
Most of the time with a GM type vehicle to get the headlights off while engine is running and vehicle is in park you just have to put the parking brake on only a click or two. That or sometimes you have the ability to turn them off by the headlight switch which is normally turned to automatic. If you turn it all the way to the right it should turn them off.
Jan 05, 2011 | 2005 Chevrolet Silverado 2500HD 2WD
Is there a way to turn the headlights off while car is running.We want to go thru Christmas display and they require you drive with park lights only. My lights come on automatically.
I THINK if you barely put on the parking brake, just enough to make the lights go off, but not drag, you will be OK. Try it and see if the lights go out when the parking brake is applied.
Dec 16, 2009 | 2004 Buick LeSabre
Headlights won't come on intermittently 2005 Dodge Caravan
Quite possibly the switch, Dodge minivans also have a front control module located under the hood, it attaches directly to the underhood fusebox, if a switch doesn't fix it I would look there.
Jun 24, 2009 | 2005 Dodge Caravan
Headlights and Blinkers Go Out Intermittently
You will need to most likely replace the lock cylinder and the ignition switch, sounds like a worn out parts issue. This should cure your problems with the lights and any other strange electrical problems.
Jul 13, 2008 | 1996 Audi A4
Mercedes M-class Ml Ml350 Ml500 Ml55 Exterior Stainless Steel Chrome Pillar Posts Trim Set 2003 2004 2005 Logo
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Jonah Oneal
xxxxxx xxx
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
