Fitbit Zip Wireless Fitness Tracker Logo
H
Helen Henry Posted on Jan 21, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
I misplaced for several months but finally found! Battery says medium but I can't get the display to work
robert
Level 3:
  • Master 2,548 Answers
  • Posted on Jan 21, 2016
robert
Master
Level 3:
Answers
2548
Questions
0
Helped
869571
Points
8043
App shows battery charge on last sync. display does not work, because it is fully discharged. recharge and then resync.
How can i turn down contrast on my laptop
Acer Aspire one
Brightness is controlled by the Fn and arrow keys.
Contrast can be controlled from the software.
FN key, + left/right arrow key's
other Acers
Log on to your Acer laptop and click on the "Start" button. Choose "Control Panel" from the menu.
Double-click on the "Display" icon in "Control Panel" and select the "Settings" tab.
Check the "Color Quality" settings and make sure they are set to either medium or high.
The high setting will give you better color quality and contrast, but it will also use more system resources and shorten battery life.
If you are operating on battery power you may want to move the setting to medium.
Hold down the "Fn" key and press the right arrow at the same time.
This key combination will increase the brightness of your screen.
To decrease the brightness and contrast, hold the "Fn" key down and press the left arrow. Continue using these key combinations until you have found the optimal setting for your laptop display.
hope this helps
1helpful
3answers
This is a Compaq Presario CQ62. It is 3 months old. The orange Compaq screen pops up but then the computer shuts down after just a few seconds. Have tried it unplugged, plugged in with and without the...
Simple test to determine if it's a hardware or software problem : try to boot in the BIOS. If you can't then it's hardware you should just return it, it's still in the warranty. If you can then Windows is totally corrupted so just reinstall it.
2helpful
3answers
As soon as turn computer on it says operating system not found -- i can get it to go to one other thing and it ask for HDD user password which i have no earthly idea what it can be
1. i hope you have backed up of all your data from the HDD.
2. format the HDD and reload the OS - but this time, make sure that you have atleast 2 partitions.
3. keep all your important in the second (non-system) partition.
4.after you have reloaded the OS, please get a good anti-virus and anti-spyware application and scan your computer regularly with them.
1helpful
My P305 will not charge the battery
A friend of mine had a bad battery. I advised her to buy a new battery, which worked fine for several months. Then she called and said her laptop would not work on battery or even plugged in. I had her buy a new charger. A week later, she called and it was not working again. We tried several things (she is some distance away) and finally I had her go get the cord from her old charger (luckily the trash had not been picked up yet) and it worked fine. So even new things can go bad - it sounds like the battery charger or the cord might be at fault.
1helpful
2007 Jeep Cherokee Transmission over temp displaying and will not start after sitting for several hours it will start? Any Ideas
I had same prob - no rhyme nor reason as to when, where or why it wouldn't start. After two new starters the shop finally found a starter wire/cable that was corroded on the inside. Mech' could move it back and forth and it would / would not start. Changed cable six months ago - no problems since. Hope it helps.
I have misplaced my Model TB-12; I need to thread the bobbin and cannot remember how, Please help; Sarah in WV
After several minutes, I finally found the instruction booklet on line, and just finished the download. Thank you
2helpful
2answers
My logitech 550 is not responding. It has worked
Hi. That message means that there is a button that is stuck down on the remote.
1. Take out the battery, push in and massage each button to ensure it is not stuck down.
2. Put the battery back in, update the firmware,
3. Update the remote.
That should get the remote working again. :)
Computer won't come on
Hi, Even if it's got one but dead cmos battery, the laptop should powerup and the worst is it will display an un-configured CMOS/BIOS. Chances are that it is something else. Try charging the laptop overnight and see if it powers up by then. You may also want to try checking on the memories, battery connectors. Post back how things turned up that we can figure other things out. Good luck and kind regards.
Top Fitbit Home Security Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Fitbit Home Security Expert? Answer questions, earn points and help others
