Cameras Logo
b
barb schoenfuss Posted on Jan 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Diagnostic error 2000
Doesnt take pictures
henryyorker999
Level 2:
Sergeant:
  • Expert 189 Answers
  • Posted on Jan 02, 2019
henryyorker999
Expert
Level 2:
Sergeant:
Answers
189
Questions
0
Helped
13209
Points
584
Customer care helpline NUMBER +1-^833_^272-^O777,,,,,,,CALL THEM
Customer care helpline NUMBER +1-^833_^272-^O777,,,,,,,CALL THEM,,,,,,,,,
Claude Kayser
Level 3:
Top Expert:
  • Master 9,098 Answers
  • Posted on Jan 21, 2016
Claude Kayser
Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5061579
Points
28436
Moultrie liebherr diagnostic Digital Cameras Questions ...
www.fixya.com > Forum > Tags > liebherr diagnostic > Digital Cameras
Moultrie digital cameras liebherr diagnostic related questions and answers. Ask your Moultrie ... 6.0 moultrie says error 2000 ACTUALLY IT SAYS...ERROR ...
moultrie diagnostic test error 000480 Digital Cameras ...
www.fixya.com > Forum > Tags > moultrie diagnostic test error 000480
Digital Cameras moultrie diagnostic test error 000480 questions and answers. Ask your moultrie ... ...moultrie says error 2000 ACTUALLY IT SAYS...ERROR ...
Moultrie diagnostic code 12 Digital Cameras Questions ...
www.fixya.com > Forum > Tags > diagnostic code 12 > Digital Cameras
Moultrie digital cameras diagnostic code 12 related questions and answers. Ask your Moultrie ... 6.0 moultrie says error 2000 ACTUALLY IT SAYS...ERROR ...
2000-0146 error in dell laptop
that error code means your hard drive is bad, you need to replace it
If you need further help, reach me via phone at https://www.6ya.com/expert/joel_63c670a84e9f6a97
1000-0143 Dell error
This error code is related to " Drive Smart read command failed."
POSSIBLE LINK to fix: -
http://support.dell.com/support/topics/global.aspx/support/kcs/document?c=us&l=en&s=dhs&docid=266787#HDD
Remove and reinstall the Hard Drive for the error codes:
  • 1000-0141
  • 2000-0141
  • 1000-0142
  • 2000-0142
  • 1000-0143
  • 2000-0143
  • 1000-0144
  • 2000-0144
  • 1000-0145
  • 2000-0145
  • 1000-0146
  • 2000-0146
  • 2000-0151
Please see the Service manual for instructions on how to remove and replace the Hard Drive. Be sure to remove and reinstall the cables for the hard drive if you are on a Desktop Computer.
After reinstalling the hard drive re-run the diagnostics if you receive the same error code Contact Us.
Run the Drive Self Test (DST) from the Utility Partition also known as the 32 bit diagnostics to determine if the previous error has been corrected. If the DST from the Utility Partition does not indicate a failure of the drive, we consider the error to have been corrected and the drive does not need to be replaced.
  • 1000-0146
  • 2000-0146
2answers
Error message 2000-0151 on dell inspirion 1545
Hi.
  • 1000-0141
  • 2000-0141
  • 1000-0142
  • 2000-0142
  • 1000-0143
  • 2000-0143
  • 1000-0144
  • 2000-0144
  • 1000-0145
  • 2000-0145
  • 1000-0146
  • 2000-0146
  • 2000-0151
  • 1000-0146
  • 2000-0146
For instructions on how to run the Dell 32 bit diagnostics click here.
Regards.
2helpful
Error 0333
The Diagnostics runs tests that need to have user interaction, Error codes below are because of no user interaction:
  • 1000-0312
  • 2000-0333
Re-run the Diagnostics while being at the Computer to interact with the Diagnostics.
or
Remove and reinstall the Video Card on a Desktop Computer for error codes:
  • 1000-0332
  • 2000-0332
  • 1000-0333
  • 2000-0333
  • 1000-0334
  • 2000-0334
so, please type more detail to be more exactly
While running diagnostics am getting an error code 2000- 0111 in my inspiron 15R laptop
If you receive an error during PSA Diagnostics, look below for the associating error code. If the Error
Error Code
Error Message
Link to Possible Fix
PSA 1000-0111
PSA+ 2000-0111
(Name of Exception) exception occurred at selector XXh offset XXh.
Contact Dell
2answers
I have a mazda familia 2000. the problem is that when i am driving, the car will start jerking as if it has run out of fuel and the engine will stop running with a minute or so. the mechanic changed the...
Get proper diagnostic test done first of all, than if you have replaced the temperature sensor, get the error codes reset in the ECU. Anyway once you get proper diagnostics done you will know what is really wrong
4helpful
Dell Inspiron 1521 Error Code 2000-0146
It means "DST Log contains previous error(s)."
Dell Support says “If the diagnostic test reports one of the above errors, refer to Dell Troubleshooting Wizard: "Hard Drive Fails the Diagnostics" Wizard ID: 324398”
http://support.dell.com/support/topics/global.aspx/support/dsn/en/tree?journalid=79E54961218510CBE040AE0AB5E158B6&treeid=324398
Camera problem
Test your webcam here - click "Allow" in top window and your webcam should show in the left hand panel
http://www.testmycam.com/
Download and run this webcam diagnostic tool - rectify any defects found - except the first ( re-boot )
http://www.download32.com/webcam-diagnostics-d35065.html
Uninstall all A4Tech software
Unplug webcam
Restart computer
Download new software from A4Tech support website
http://www.a4tech.com/ennew/support.asp
Jul 19, 2009 • A4tech PK5
Nec versa e 2000
Whats the device for the ports you are checking? A drive? diagnostic won't tell you if ports are damaged. Doesnt work that way, if they are damaged, extract the drive from the case and move on. Diagnostics will only tell you info on the drive.
Keep me posted.
Top Cameras Experts
ZJ Limited
ZJ Limited
ADMIN Andrew
ADMIN Andrew
Are you a Camera Expert? Answer questions, earn points and help others
