Mitsubishi DD-6030 DVD Player Logo
Tom Riley Posted on Jan 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Is my mitsubishi dd 6030 a multi region player
Claude Kayser
Level 3:
Top Expert:
  • Mitsubishi Master 9,098 Answers
  • Posted on Jan 21, 2016
Claude Kayser
Mitsubishi Master
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5063788
Points
28436
Mitsubishi DD-6030 DVD Player Multi region hack ... - Fixya
www.fixya.com > ... > Mitsubishi > Mitsubishi DD-6030 DVD Player
Mitsubishi DD-6030 DVD Player, multi region hack related issues. Get free help ...Can you help? I need the multi region code for my Toshiba DVD SD370E. Ad.
Mitsubishi DD-6030 DVD Player Multi region hack code ...
Mitsubishi DD-6030 DVD Player, multi region hack code related issues. Get free help ... I need the multi region code for my Toshiba DVD SD370E. Ad. Question ...
Mitsubishi DD-6030 DVD Player Real free - Questions -Q&A
www.dqrkc.com/search/p153978-mitsubishi_dd_6030...player/real_free
I use them on all my disk players and they work real well. If you have any comments please feel free to leave them here. Hope this helps and thank you for using ...
Planet DVD Discussion Forum - planetdvd.net
www.planetdvd.net/discussion/wwwboard2.htm
DVD region hack available?
If you suffer from region code troubles, you can download a region free DVD player software tool on your pc and then you can play discs of any regions you want. You can try Leawo Blu-ray Player which is a free Blu-ray player and a region free player.
Dvd plays, music plays, talking at a whisper
My
dd-6030, music plays, talking at a whisper. Any suggestions?
2answers
Multi Region Code Support
SEE THE INSTRUCTION. GOD BLESS YOU
  • 1
    Turn on your DVD player.
  • 2
    Open the DVD player's main drive, also commonly called the DVD "tray." The region cannot be changed while a DVD is in the machine, so many DVD players require the tray to be open as an extra precaution.
  • Sponsored Links
  • 3
    Push "Info" or "Setup" on your remote.
  • 4
    Use the remote to select the "Region" option as indicated on your TV screen.
  • 5
    Select "Region 9" to change the system to multiregion formatting. Regions 1 through 8 represent specific geographic locations and will not allow multiregion playback.
Read more: How to Change a DVD Player to Multi Region ' eHow http://www.ehow.com/how_5121939_change-dvd-player-multi-region.html#ixzz2VzwQi6NL
How to unlock mitsubish dd6030
follow the steps: God bless you
Purchase or borrow an imported DVD. The only real reason to make your DVD player region-free is if you plan on watching imported DVDs.
  • 2 Locate your DVD player's brand name and model number. These can usually be found on the box the DVD player came in, or on a sticker close to the video inputs or on the bottom of the DVD player.
  • 3 Have your remote handy. You will need your remote to enter the input codes into your DVD player.
  • 4 Locate a Web site that can help you with the codes you need for your particular DVD player, since all DVD players have different codes. Try DVD Exploder or Video Help (see Resources below). Both have an extensive list of codes for almost every kind of DVD player manufactured.
  • 5 Enter your brand name and model number when prompted to do so on the Web site. If your particular model number is not available, try searching under the brand name. Sometimes you will be able to find a model number that is close to your DVD player's model number.
  • 6 Enter the codes into your DVD player with your remote. Be sure the DVD player's door is open-almost all codes require the door to be open.
  • 7 Test your imported DVD to see if it works, once you have entered your code into the DVD player.
  • 0helpful
    Unlocking mitsubishi dd 6030
    follow the next step:God bless you
  • 1helpful
    The dvd player plays, there is sound, but there is no picture being transmitted from the video out (yellow plug).
    Hello:
    Try to swap the plugs, yellow in red, red in yellow, also try to swap the yellow, and white plugs.
    3answers
    Code
    I need a new remote control. My remote control just stopped working.
    Dvd player will not open
    remove the 5 screws that hold on black cover. inside there is a white gear that will retract mechanism. Two gold screws on plate that covers dvd need to be removed. lift off cover and remove dvd.
    2answers
    DVD not loading
    you have to look on the back of your dvd player to see what region your player is then you will have to check the dvds that you have from colombia and warner bros and see what are thier region.you dont have to purchase a new dvd just dont buy or rent dvds from the above mention place.if the region on the dvds of both place do not match your dvd player you will be wasting your time.good luck.
    Top Mitsubishi Televison & Video Experts
    matt martin
    matt martin
    Grand Canyon Tech
    Grand Canyon Tech
    Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
