RCA CA 7" Tablet with 4GB eory 28458515 Logo
m
michelle Rader Posted on Jan 20, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why wont my tablet connect to the wi-fi
I have reset to the factory settings and it still wont connect to the WI-FI
ken pullen
Level 2:
Sergeant:
  • Expert 257 Answers
  • Posted on Jan 20, 2016
ken pullen
Expert
Level 2:
Sergeant:
Answers
257
Questions
Helped
53435
Points
669
Have you opened settings and entered your WI FI password /key: ,if you have not you will not be allowed connection . hope this helps.
How to keep Wi-Fi connection on XGody tablet?
Not a good make.
Wi-Fi Keeps Disconnecting on Android? 11 Ways to Fix
  1. Toggle Airplane On/Off. ...
  2. Check the Signal Strength. ...
  3. Forget and Re-add Network. ...
  4. Remove Obsolete Wi-Fi Networks. ...
  5. Restart the Wi-Fi Router or Modem. ...
  6. Reboot Android Phone. ...
  7. Disable Adaptive Wi-Fi and Adaptive Connections. ...
  8. Update or Reset Router Firmware.
More items...
Sep 22, 2022
Why does my verizon tablet keep disconnecting from wifi and not accepting my pasword to get back on
There could be several reasons why your Verizon tablet keeps disconnecting from Wi-Fi and not accepting your password to reconnect. Here are some possible solutions:
  1. Restart your tablet and your Wi-Fi router: Sometimes, simply restarting your tablet and router can help resolve connectivity issues.
  2. Check your Wi-Fi signal strength: Weak Wi-Fi signal strength can cause frequent disconnections. Move closer to the router or try to improve the signal strength by repositioning the router or using a Wi-Fi signal booster.
  3. Check your Wi-Fi network settings: Check if your Wi-Fi network settings match those of your router. Make sure you have the correct security settings and password. Try to forget the network and then reconnect and re-enter your password.
  4. Clear your tablet's cache: Clearing your tablet's cache can sometimes help with connectivity issues. You can do this by going to Settings > Storage > Cached data > Clear cached data.
  5. Check for software updates: Make sure that your tablet is running the latest software updates. Check for updates in Settings > System updates.
  6. Factory reset: As a last resort, you can try doing a factory reset on your tablet. This will erase all data on the tablet, so make sure to back up any important files before doing this. Go to Settings > Backup & reset > Factory data reset.
If none of these solutions work, you may want to contact Verizon customer support for further assistance.
2answers
Zte tablet model k88 wont connect to wifi
Weak wifi signal or defective tablet or router.
My Kindle is not recognizing my wi-fi signal. No Wi-Fi signals show up on the list. I have tried several times to turn the Wi-Fi on and it doesn't work.
I would recommend backing up all of your data and reset the device to factory setting and try again. Sometime software have glitches and required a complete factory reset.
2answers
My tablet keeps saying Avoided poor internet connection every time i try to connect and ive tried everything reseting, turning on/off the wifi everything and it still wont work
If other devices work ok on the same Wi-fi, then the tablet should, as long as it's near the Wi-fi router but not too close to it.
2answers
My toshiba tablet wont connect to my wi-fi please help
1. Make sure that your wi-fi settings are turned on.
2. Scan for local wi-fi
3. Select your desired wi-fi and provide password if required.
Many times, the settings from the menu are not turned on, so the tablet will not try to link to a wi-fi site.
If you need more help, please provide the model number and the operating system currently being used on the tablet.
1helpful
Cant get wi fi signal.
Solution 1.Check wireless connection.
The first step of diagnosis have to any other device connected to the same network, ensure the wireless connection is working fine, or verify the settings of your wireless router to correct it.
2.Check your Keep Wi-Fi on during sleep Settings.
Owing to Wi-Fi sleep policy your Wi-Fi connection may be going to get disconnected every now and then.
Tweak this policy to keep your Wi-Fi connection awake.
[Settings] >>[Wi-Fi]>>[Advanced]>> Check [Always] to keep the Wi-Fi on during sleep.
Save changes and exit all the screens. Your Wi-Fi will never get disconnected again due to this policy.
3.Check signal strength of wireless connection.
The performance of a wireless network connection depends in part on signal strength.
You have to connect the Wireless network where the signal strength is strong.
Check Wireless network signal strength icons in notification bar.
4.Try to turn off/on Wi-Fi on the device.
First to turn off Wi-Fi, [Settings]>>[Wi-Fi] >>[turn Wi-Fi to off].
And then to turn on Wi-Fi, [Settings]>>[Wi-Fi]>>[turn Wi-Fi to on].
5.Try to forget network on the device.
Forgetting wireless networks allow your tablet/phone to reset some settings.
[Settings]>>[Wi-Fi]>>Press & hold your[Net Work Name(SSID)]for 2 seconds.
>>Select[Forget Network]>>Re-Connect your wireless networks if it's disconnected.
6.Try to reboot your device.
7.Make sure your firmware is up-to-date.
>>Select[Settings]>>[About tablet]>>[System Firmware Update]>>[Check Update].
8.Try to reset your device.
Note: once RESET was performed, all data, apps, settings and personal information will be deleted after initialization.
Third-party programs might be the major probability of Tablet/Phone instable, suggested to have a full reset for the device if the situation persists.
[Settings]>>[Backup&reset]>>[Factory data reset]
9.Try to other wireless connections.
If steps above were not able to solve internet connection problem still, please try other wireless connections if available, otherwise contact your networking provider to technical support.
2helpful
Will not connect to wifi
  • Touch the Apps Menu button on the Home screen.
  • Open the Settings app.
  • Choose Wireless & Networks.
  • Choose Wi-Fi Settings.
  • Ensure that Wi-Fi is on.
    When you see a green check mark next to the Wi-Fi option, Wi-Fi is on.
  • Choose a wireless network from the list.
    Available Wi-Fi networks appear at the bottom of the screen. When no wireless networks are listed, you're sort of out of luck regarding wireless access from your current location.
    Optionally, type the network password.
    Touch the Password text box to see the onscreen keyboard.
    Touch the Show Password check box so that you can see what you're typing; some of those network passwords can be long.
    Touch the Connect button.
    You should be immediately connected to the network. If not, try the password again.
  • 0helpful
    My new zte v9 wont connect to the Internet
    you can access the Internet through the mobile network or via Wi-Fi.Your mobile network settings are pre-configured by your serviceprovider and there is no need to change any settings. Wi-Fi Wi-Fi provides wireless Internet access over distances of up to 100meters.1. Tap Home > Settings > Wireless & networks .2. Select the Wi-Fi check box to turn Wi-Fi on
    Top RCA Tablets & eReaders Experts
     Mikey
    Mikey
    k24674
    Are you a RCA Tablet and eReader Expert? Answer questions, earn points and help others
