Question about D-Link DSL-2640B Wireless 11/54Mbps ADSL2+ Modem/Router with 4-port 10/100Mbps switch
Rear dial function skips - D-Link DSL-2640B Wireless 11/54Mbps ADSL2+ Modem/Router with 4-port 10/100Mbps switch
My rci 2950 is skipping channals why and how do i get it fixed?
skipping all by itself or skipping when dial is turned only ? if it skips only when dial is turned , switch contacts inside can be cleaned using knob/potentiomer cleaner in spray can (don't allow it to ruin front cover as its nasty to painted or chromed plastic )
Sep 27, 2016 | Radio Communications
Skip channel function not working coreectly
db:: 4.90::Fios tv VMS1100 skip not working correctly k3
www.hivmr.com/db/k37cmjfzkk71s913ksf3j7xfxsz3zc37
DB:4.90:Fios Tv Vms1100 Skip Not Working Correctly k3 ... Pressing Play on the remote has no effect, but changing the channel fixes everything. ..... The functions Skip Forward, Skip Backwards, Next Chapter and Previous Chapter all skip ...
The Secret Method to Skip Commercials with One Button on ...
Dec 28, 2015 | Televison & Video
How to retrieve messages when not at home? Model 26976GE 1A
REMOTE ACCESS
This section explains the remote access process for use with any touchtone
phone.
1. Dial the phone number for the answering machine.
2. After the answering system answers, press any numbered key on the
touch-tone pad to bypass the outgoing announcement, or wait until
the announcement finishes.
3. Enter the security code after you hear the tone.
4. Follow the voice menu to use the answering machine's remote functions.
The remote feature enables you to perform the following functions:
To Press this button
Review message 1
Play back messages 2
Stop message play back 2
Erase message 0
(during message playback)
Skip message 3
Turn off/on answerer 4
Review voice menu options 7
No valid dialing tones for 15 seconds will hang up the telephone line.
You can get the manual on the link below if you need page 31.
http://www.home-electronics.net/USER-GUIDES/26976_DOM_ES_CL_IB.pdf
Good luck
Dec 04, 2010 | GE Spacemaker 26976 Cordless Phone
MFC-490cw Color Inkjet Multi-Function Printer: how to send a fax...
Most of these will send a fax without even using the PC. Just connect a phone line, place the document in the proper position, usuallu print side up on newer models, and push the fax button, it should prompt you for the number. Once dialed,, the paper will feed into the scanner portion of the multi, and you will see it on the menu bar saying sending page 1, 2 etc, after if is done sending, it will dial and connect, yu should hear the typical noise a fax makes. then it will say fax sent or end or something similar, that's it, try sending one to a friend to make sure it's working. Now some simpler machines require you to open the scanner portion and lay the paper down in the glass manually, mine does it both ways. In that case just skip the feeding part, and dial wait for it to scan and send.
May 16, 2010 | Brother MFC 490cw Color Inkjet...
How do you find and use the self-timer setting?
Hello.
Turn the function dial to the drive mode position.
Press the function button in the center of the dial.
Turn the front control dial to select the self-timer drive mode.
Use the rear control dial to to switch between a ten-second and a two-second delay.
Press the shutter-release button partway down or press the function button to set the mode.
When you are ready to take the picture.
Press the shutter button partway down to set the focus and exposure.
Press the shutter button all the way down to start the timer.
Hope this helps.
Feb 16, 2010 | Konica Minolta DiMAGE A1 Digital Camera
I CAN`T SEND A FAX
Fax machines are sorta like printers, sorta like scanners, and sorta like dial up modems all wrapped into one expensive box.
1. First thing to make sure of is that you are hooked to a phone line. most fax machines have a phone handset that you can make calls from. Call someone and make sure that works. If So, you are able to connect to phone networks, and should have no trouble sending or receiving data. If you have a dead line or no sound, check the line and check the power. (its always the easy stuff that is overlooked, just check it and make sure).
2. If this fax machine has computer interface, (usb port or parallel cable port), see if you can scan with it. Drop a document into the scan area and see if the computer can scan an image from the scanner. If the scanner works, you can scan images into the fax machine to be sent to the fax number. (If your fax machine does not have a scan to computer feature, skip this.)
3. if your fax machine has a print from pc feature, try to print a document to it from your computer. If you can print, then the printer works, and you can receive faxes. (if your fax machine does not have a pc printing feature, skip this)
4. Here is how a typical fax machine works. You place the document or image into the scanner feed area. You press a big button that usually says "fax" and then, a screen pops up saying to dial the number. You dial the number and press SEND. once you press Send, the machine will scan the document, dial the number and sing a little dial up modem song awaiting a response from the receiving machine. the receiving machine acknowledges the fax, and the singing is no longer audible (but it continues because the modem song is actually data transmission/reception). after about 20-60 seconds, the fax completes and the call ends. As for the particular model you have, the functions should be about the same, though the buttons and arrangements may be different. FYI, you can send a fax straight from the PC too, if you have a dial-up fax/modem card.
Jul 03, 2009 | Brother Multi-Function Center MFC-665CW...
Dialing in to get Voice Messages.
After the answering machine beeps for you to leave a msg - enter the 3-digit security code. If you haven't already set that function up, the default is 1-2-3.
Once in, use these buttons for:
#1 - Review msg
#2 - Play back msg
#2 again to Stop the play back
or #0 to delete during play back
#3 - Skip
#4 - Turn off/on answer
#7 Review voice menu options
Mar 26, 2009 | Uniden Cordless Phone
Getting started with the ICOM IC_R5
First set the squelch (gets rid of the hissing noise and allows the radio to scan)
to do this....
On the side are 2 buttons, the bottom one is monitor.
press and hold then look at the display,
turn the top dial until "AUTO" appears,
The squelch should now keep the radio quiet.
Now the tuning step..
You need to set this because if your radio was on 450.000 and you wanted to listen to 450.012.5 you would miss it if your radio was making 000.025 "steps". IE you would need 12.5 steps. This is the most common step used by ambulance etc in the UK, you will need to check local band plans.
Stick with 12.5 and you should get most stuff on VHF / UHF.
For airband 12.5 will get most stuff, but some is now changing to 8.33.
For HF (below) 136 Mhz I'd use 5
To set the step....
On the front there are 4 big buttons.
press [V/M.S.MW.SKIP] to select VFO mode,
then press [BAND.LOCK] to select the band you want to listen to,
then press [TS.SET] to enter the step
turn the dial to select your step (stick with 12.5 for now)
press [TS.SET] to exit back to VFO mode
To scan...
First set the scan type...
Press and hold the one that says [MODE.SCAN] for 2 seconds and look at the display,
turn the top dial until the screen reads ALL,
press [MODE.SCAN] again and the radio should start to scan with the 12.5 steps you set earlier.
If you want to change scan direction, just turn the top dial.
If you want to stop the scan, just press [MODE.SCAN].
When you hear something interesting, make a note of the frequency on the display.
To set memories (store frequencies).....
to get close to the frequency you made a note of, press [BAND.LOCK]
Then set the actual frequency with the top dial,
press and hold [V/M.S.MW.SKIP] for 2 seconds to select memory write mode (1 short and 1 long beep)
turn the top dial to select which channel you would like to overwrite. Start with 01.
press [V/M.S.MW.SKIP] for 2 seconds. ( 3 beeps )
Thats it!
Any more problems just post on here and either me or someone else will help.
M3ODQ
Jan 31, 2009 | Icom IC-R5 Handheld Scanner
Small dial on the watch face that counts the minutes won't return to zero. It still functions but when the 'reset' button is pressed, all other dials but this one return to their zero setting. Watch is a...
Check in the instructions if there is a way to re-sync the hands. For some models of watches the hands are able to be calibrated.
It is also possible that the watch has a problem. Either the dial hand is not properly seated on to its axel, or the drive gear that is under the axel skipped a tooth. You will have to find someone who can service watches to fix this for you.
Jerry G.
Nov 21, 2008 | Jaeger-lecoultre Reverso Classique 2798170...
I have a Beko washer WMA 1613S and recently the programme dial is skipping through the set wash functions without performing all the relevant actions in the cycle. This seems to occur on all number...
I have a Beko washer WMA 1510S and recently the programme dial is skipping through the set wash functions without performing all the relevant actions in the cycle. This seems to occur on all number settings.
Andrea
Aug 30, 2008 | Washing Machines
D-Link DSL-2640B Wireless 11/54Mbps ADSL2+ Modem/Router with 4-port 10/100Mbps switch  Logo
60 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Mike
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
