If you have an S-Drive controller both the top speed and the reverse speed can be programmed into the controller through a programming port look on YouTube for programming your scooter S-Drive controller and some of controllers also have this feature
Buy penegra 100 Online is used for High blood pressure, and other Conditions. buy penegra online Lowest price at Medypharma. penegra 100mg uses is contain of Sildenfil citrate 100mg. penegra 100mg review.
Cud b old batt or bad connection etc
SOURCE: golden companion 2 scooter moves slow in reverse
i would suggest there is either a loose connection or the speed control has failed, the scooter will still run but at a slow speed, the part is fairly standard in all scooters. if i can be any furthur assitance please email me rick @ lxrixta.co.uk (remove the spaces)
SOURCE: i have a mayfair 4 weel scooter and the problem is
Hi, where's the clicking sound coming from ?
Is it from the back of the scooter ? remove the rear cover under this to located the sound if it get quieter at the rear then it must be related to the front control panel; that houses the speed pot or throttle control whatever you want to call it,
it may be the speed pot is faultly and as you say not lot of power , I suggust to try moving the throttle lever in the upward direction while going forward , if this improves things then that the fault,
Regards
GeWiz.
SOURCE: Rascal mobility scooter will now only go backwards
On some scooters it is possible to change the polarity of the motor. If its a two brush motor (most are) you can just swap the red and black wires around in the connector plug for the motor. Make sure you get the right wires if you do this but I have to point out that there is obviously a problem with the scooter and I would strongly advise you to get it looked at by your local dealer as the problem is potentially serious and may cause other problems aswell. I cant really understand why it would only go backwards. May be a throttle pot problem or main controller fault. Either way, as I said, best get it looked at as even if you do swap the wires, it is most likely that the scooter will only travel forward at the usual speed for reverse, normally 2mph! Hope this helps...
SOURCE: my scooter goes backwards when i push the forward
Mickey
It would depend on what model Compnanion Scooter you have. The latest version has a Delta Tiller and these are designed to be pulled towards you as opposed to being push away. Trust me it is an ergonomic thing. However, if your scooter does not have a Delta Tiller the wiring may be reversed.
The best bet is to call Golden's Technical Service Dept. at
1-800-624-6374 Ext 501
SOURCE: Just bought anew pride 2
Here is what another tech here on FixYa said about a similar problem, and so before we go guessing at bad parts, see what he says:
http://www.fixya.com/support/t2475887-pride_victory_xl8_problem_running
The unit could be just limiting itself from overheating, but since it's so new, I would enforce the warranty to have it check, just to be safe.
Consult your retailer it was purchased from to find out how to enfore your warranty.
Good luck, and hope this helps.
