Timex Nature Sounds LED Clock Radio Logo
A
Anonymous Posted on Jan 20, 2016
How to set timer? - Timex Nature Sounds LED Clock Radio
I have two Intermatic wall switch timers: Easy set timer model SS7 and one with number 154ST24898. Any idea ho to program these?
Crystal Air ozone machine support
https://www.bing.com/images/search?q=easy+set+timer+model+154st24898&qpvt=Easy+set+timer+model+154ST24898&qpvt=Easy+set+timer+model+154ST24898&qpvt=Easy+set+timer+model+154ST24898&FORM=IQFRML
Need instructions to set timer
1) Copy following link for setting analog timers:
http://waterheatertimer.org/How-to-set-timers.html
2) Copy following link for setting outdoor timers:
http://waterheatertimer.org/Woods-timers-and-manuals.html#outdoor
3) Add comment and describe timer in detail, and/or attach phot so timer can be identified
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Timer does not come on when set
Timer is not identified.
I don't have repair for defective timer.
1) Open following link to help identify timer, and then add a comment with timer number and description how you set timer, and what you have tried so far:
2) Open following link to see how to set analog timers, and read troubleshoot steps, and then add a comment with as much information as possible:
3) Add a comment and describe timer in detail and what you have done so far so timer expert is not guessing.
Do I set the GE timer # 15089 to Auto on or Auto off for it to be activated. I had it on Auto on however the light stayed on all the time.
Open following link to identify timer and download manual:
http://waterheatertimer.org/GE-timers-and-manuals.html#15089
Timer should be set to Auto ON for timer programs to run.
Auto OFF is temporary override, and timer resumes schedule at next set point.
ON is always ON
OFF is always OFF
If timer is not operating as expected:
Test outlet for correct polarity and electrical problems using cheap circuit analyzer from hardware store.
Timer programs can have conflicts. Make schedule before setting timer so there are no overlaps that cause timer not to function as expected.
Current time has not been set. Set current time including current day.
Set button has been accidentally pushed, and a number or CTD appear in display.
Timer needs to be reset to clear conflicting programming or error. Push reset button with paperclip and try programming again.
Timer is not able to handle intended load. All timers work for incandescent bulb. Connect timer to incandescent lamp and see if problem continues.
Timer is defective. Buy another timer from Home Depot and return defect in new package.
I installed the GE Basic Timer 15070 ok. I set on and off times followint the insdtructions several times. The time will tunr the light on at the set on time but it never turns the light off at the set off...
Something doesn't sound right.
I have two of these timers and cannot figure out what your timer is doing, unless wiring is wrong or timer is defective, or you connected timer to 3-way switch.
15070 is single pole analog timer that requires neutral wire.
Slide switch is set to 'Timer' for automatic timer functions.
Open following links to identify timer and see wiring and how to set analog timers:
http://waterheatertimer.org/GE-timers-and-manuals.html#15070
http://waterheatertimer.org/images/GE-15070-wiring-1-500.jpg
http://waterheatertimer.org/images/Woods-59017-mechanical-timer-300.jpg
http://waterheatertimer.org/Woods-timers-and-manuals.html#59017
Can not set up my hydrofarm timer to come on for 1 min and off for 5 min.
You posted next to a photo showing hydrofarm analog timer with segments located on dial face.
Open following link for general look at setting analog timers.
Analog timers have a minimum set time of 15 minutes because the trippers-or-pins-or-segments are made certain width.
If you want 1 minute ON and 5 minutes OFF, you need digital timer.
Most digital timers have minimum set time of 1 minute.
But digital timers have limited number of set points per day unless you get into heavy-duty Intermatic timer like the ET70115 timer with 100 or so set points.
If you want 1 minute on and then 5 minutes off, and want to repeat that same cycle over and over throughout the day and night, you would need 240 set points.
Or check out 120V adjustable cycle timers.
https://www.grainger.com/Grainger/cycle-timers/timers/electrical/ecatalog/N-8hbZ1z0q55s
If you want the cycle timer to operate certain hours only, then put ordinary 24-hour timer between the cycle timer and the load.
Add a comment for more help.
Upvote the help.
And take advantage of fixya expert assistance live.
For a price, expert works with you while you work on timer or any do-it-yourself project.
Fixya is always less expensive than a service call.
1helpful
Do not know how to set timer DT300 for Lights
Hi
Programming:
Set present time
Then set ON time for program 1
Set OFF time for program 1
Then set ON time for program 2
Set OFF time for program 2
Most timers will not function if there is a conflict in programming > for example Program 1 says ON at 6 and OFF at 7 and Program 2 says opposite or has overlapping times
When events are set, press SET once > this will put timer in RUN mode
If manual override works, and you set programming correctly, but timer does not carry out instructions, I guess the timer is no good.
Intermatic has 24 hour timers with 2 on-off per day
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/lamp%20%20appliance%20timers.aspx
Intermatic has 7-day digital timers (all digital timers today are 7 day where you select the day that each program works)
http://www.intermatic.com/products/timers/consumer%20indoor%20timers/digital%20timers.aspx
Thanks.
How do you set the timer
You posted under Woods outdoor timer:
See this timer and other similar types to identify your timer for sure
http://waterheatertimer.org/Woods-timers-and-manuals.html#2001
If this is not your timer, look at other timers on the page and then add a comment, and I will post instructions for another timer.
Generally this type of timer each set the same way:
Instructions:
Timer tuns ON automatically at dusk
Use dial to set 4 possible options:
Set dial to Off , the timer is always OFF
Set dial to ON, the timer is always ON
Set dial to Dusk-Dawn, the timer is ON at dusk, OFF at dawn
Set dial to 2,4,6,8 hours, the timer is ON at dusk, lights OFF 2,4,6,8 hours later
You can also take advantage of fixya phone support.
Fixya expert will walk you through the steps for a price.
How do I set it and can I use it indoors?
I see nothing in the manual that says 'outdoor use only' EXCEPT timer runs on photoelectric eye.
Timer turns ON automatically at dusk, so if timer is inside, and indoor lights are ON, then timer stays OFF.
http://www.intermatic.com/~/media/files/intermatic/products/instructions/timers/hb51rc%20-%20english.ashx
http://www.intermatic.com/products/timers/consumer%20outdoor%20timers/electromechanical%20timers/hb51rc.aspx
To use timer outdoors.
Plug timer into wall.
Timer turns ON automaically at Dusk.
Rotate dial to set how long timer will stay ON.
Set timer to turn OFF 2 4 6 8 Hours after dusk
Set timer to turn off at dawn
Set timer to ON so lights are ON full time
Set timer to OFF so lights are off full time.
Top Timex Audio Players & Recorders Experts
 Grubhead
Grubhead
John
John
Are you a Timex Audio Player and Recorder Expert? Answer questions, earn points and help others
