SOURCE: hi,dyno glo heater.as long as i hold the pilot in
The thermocouple from the burner flame port to the gas valve is bad. Shut your gas supply off, unscrew the small fitting with the small copper tubing coming out of the gas valve. Follow that tubing up to the burner and disassemble the pilot light end from the burner. Home Depot has a good selection normally or you may want to go to a furnace supply. It shouldn't be more than 10 or 15 dollars for the new one. Reinstall, turn the gas back on and make any adjustments to flame location at the burner.
