K zaveri
The pole the U clamp is attached to should be able to be removed. My own shower has a similar set up. The pole's top and bottom mount's front has a pop out of which has a screw underneath. Once you remove the screw the top bracket can be pulled aside and the pole removed so the U clamp can be slid off. I hope this design works for you as well
Have a good day,
SOURCE: Grohe 24'' Relexa Shower Swivel Hand Shower Holder broke!
Try going to this web page and looking up the nearest parts carrier in your area.
http://www.groheamerica.com/t/25_3859.html
sanray
SOURCE: leak where Grohe shower head attached to the threaded pipe
using a pair of vice grips wrapped in a soft towel( to prevent scractching) turn the shower head in a counter clockwise direction to remove it then apply liquid teflon (real-tuf) to the threads on the shower arm and tighten the shower head but dont over tighten it liquid teflon is more effective at sealing leaks than teflon tape and it can be wiped clean
SOURCE: low water pressure in grohe hand held. Is there a
1 Check if the holes in the hand held shower are not clogged with scum which generally happens over prolonged use. Clean them with a pin. 2 If this does not help, then check the the pipe connecting the shower to the water outlet. It should be clean and not clogged with foreign material which restricts the flow of water. 3 It still it does not help then you may have to fix a booster pump or raise the level of the water reservoir.
SOURCE: I have a axor Grohe shower head ona rail. It is starting to slide down the rail on it own.
There may be a tension adjustment screw on the slider that you can adjust to add tension between the slider and bar. If it is an Axor or Hansgrohe wall bar You can call Hansgrohe Technical services. We can help you identify and adjust or reapir this unit. Feel free to give me a call at 1-800-334-0455. Ask for David Scarborough. I'd be happy to help.
