Cameras Logo
A
Anonymous Posted on Jan 20, 2016
When i turn on my camera canon power shot A610 with the setting on auto the screen is still blank and i get no picture, what am i doing wrong ?
A610, 5.0 mega pixels; new batyteries installed
Paul Green
Level 2:
Prodigy:
An expert who has answered 500 questions.
  • Canon Expert 527 Answers
  • Posted on Feb 06, 2016
 Paul Green
Canon Expert
Level 2:
Prodigy:
Answers
527
Questions
Helped
232943
Points
686
Have you tried pressing the display button 2 or three times?
5 Related Answers
Anonymous
  • Posted on Jul 19, 2008
SOURCE: CANON POWERSHOT S2 IS 5 MEGA PIXELS
I bought mine 2 1/2 yrs ago too. Found this solution on this site and tried it. It worked perfectly.
Turn to TV mode, set the exposure to 15 seconds by pushing the little "arrow dial" until you have 15"
Push the button to take the picture.
Wait 7 seconds from when you push the button, then turn over and open the battery door while it is "taking the picture."
Close the battery door and turn back on.
I did this three times and the last time, it worked and the iris became unstuck.
Then I took a million pictures to get the iris moving.
Anonymous
  • 3 Answers
  • Posted on Dec 31, 2008
SOURCE: shows up black screen when turned on
I have the same problem with my Canon S21S, and I was blown-off by Canon "Support" a long time ago. They won't fix them even though it is the same problem as with the S11S because they're too cheap to spend the money.
So my solution is simple: DON'T BUY ANYTHING MADE BY CANON! EVER!
Anonymous
  • 164 Answers
  • Posted on Jul 22, 2009
SOURCE: canon power shot S2 IS 5 mega pix camera it just shows a black sc
Your camera has the know issue of Stuck shutter, whichhappens after some time (weeks or months) thata camera is notused.
Unfortunately the repair of it requires a complete disassembly of the camera, including the lens, fix it, and then put back together everything.
Definitely requires th skills, tools and experience to do it, so it's recommended that a professional camera repair center is performing this type of repair.
If you look for a reliable and low cost repair service for it, you can look in ebay for such repair services.
Example, look for seller ID Great_items_2004 or with the keywords "Shutter black S2".
Best regards,
t00nz
CameraR
  • 4738 Answers
  • Posted on Dec 30, 2009
SOURCE: Power Shot A620 Canon 7.1 mega pixel 3 years
A stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open).
To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help:
Anonymous
  • 11 Answers
  • Posted on Mar 19, 2010
SOURCE: Need to know where to obtain manual for Canon
http://dl.owneriq.net/4/4696ea04-0d04-2854-5de4-050c8c52b34b.pdf
Canon power shot A610, will it support sundisk 16GB?
No. The A610 works with MMC and SD cards, 2GB or smaller. It will not work with higher-capacity SDHC cards.
Blank screen on Canon A610 Power Shot. Can't view pictures taken or from memory card.
Are the downloaded pictures also black when viewed on your computer? If so, a stuck shutter is another common failure mode for digital cameras. The symptoms of a stuck or "sticky" shutter are very similar to CCD image sensor failure. The camera may take black pictures (for shutter stuck closed), or the pictures may be very bright and overexposed, especially when taken outdoors (for shutter stuck open). To confirm a stuck shutter, put the camera in any mode other than "Auto", and turn the flash OFF (you don't want to blind yourself for the next step). Next look down the lens and take a picture. You should see a tiny flicker in the center of the lens as the shutter opens and closes. If no movement is seen, then you likely have a stuck shutter. If so, please see this link for further info and a simple fix that may help.
1helpful
Need to set date stamp but,the menu screen skips over the date stamp on/off and its set to off. POWER SHOT A620
You can only do this when the camera resolution is set to postcard mode.
See pages 33 and 34 of the user manual (courtesy of the Emerson College website).
If my reply has answered your question then please rate my answer accordingly.
Blank Screen on a Canon Powershot A610
The powershot a610 will not take pictures screen is blank. it will show previous pictures but nothing new
2answers
Digital Camera Malfunction
its a problem with the iris of ur camera and also sumtimes the CCD .... get it repaired from a repairman
1helpful
5answers
LCD screen stays dark
I have the same problem and very frustrating! The camera turns on by won't show anything (totally black) in the camera mode. The menu still works. If I take a picture the display is black and shows black for it in the display mode model as well. Tried everything that I can think of but nothing helped. (Taking out the batteries and reinstalling, switching the mode from display to camera and back, stepping through each mode option, stepping through each menu options). The last option worked once but won't work later on. From this forum this seems to be a common problem with this camera. Guess won't buy another camera from Canon any more. I bought a camera (non-digitals SLR) from Canon before and was very happy with it for over 20 years. Thought Canon had the right thing in camera. This problem made me think twice when I buy another camera in the future. Perhap Canon is not as good as I thought. By not fixing the known problem, they are ruining their reputation.
E 18 problem
broken lens on Powershot SD600
Feb 17, 2008 • Cameras
Top Canon Cameras Experts
old marine
old marine
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Canon Camera Expert? Answer questions, earn points and help others
