Sony Bravia KDL-46V4100 46 in. LCD HDTV Logo
A
Anonymous Posted on Jan 20, 2016
The tv keeps turning itself off. The red light is blinking after the tv turns off
I've tried unplugging the power source and plugging it back in. The tv will go on and after about 15 seconds turn off. I unplugged it from the power strip and plugged it directly into a socket. Still turns itself off.
Level 3:
Top Expert:
  • Sony Master 76,851 Answers
  • Posted on Jan 20, 2016
Sony Master
Level 3:
Top Expert:
Answers
76851
Questions
30
Helped
14983645
Points
237762
Fault at its main digital board. Short circuited component/s at it. Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts.
http://electro-medical.blogspot.com/
In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary.
2helpful
2answers
LG led tv keeps blinking
It could be the conection ribbon between the T com and main board remove carefully clean and replace ,it should do the trick if still the same then most likely T -com
My flat screen tv wont turn on but the lite at the bottom just keeps blinking red what does that mean its a sony tv
Unplug the tv from all devices and unplug from the wall power source. After about 15 minutes, plug ONLY the power cord back in and see if it turns on. If not, than you will need to do a factory reset. With the tv pluged into ONLY the wall outlet ( no cable, DVD or internet connection) Hold the UP arrow on the remote than press and release the POWER button on the tv. This will reset everything and the blinking red light should stop. At this point you should be able to turn the TV on and off.
IF for some reason this does not fix your issue, visit HTTP://esupport.sony.com
Good luck.
Welcome to Product Support Get the help you need
Turned itself off. I turned it back on and power button blinks green for a few seconds then blinks red continuously. red light by card reader blinks red about every five seconds. No picture, no sound.
unplug it from power source completely 15 minutes then plug back in with NOTHING plugged into any of the ports. If it boots back up then does it again later it make be something plugged into a port causing power to back feed into the boards. I had this same issue on my plasma last year ended up being the xbox360. After this if it still wont power then your power board maybe bad.
How to repair Sharp TV 17 Flat Television 17C-FN70?
this is what I've done to our tv, same problem so I solved it by doing ths : first turn on your tv then let it keep on blinking then directly unplug the tv don't turn off the tv . plug again the tv then you'll see that second red light is not blinking but still it still red light the first one, just unplug it again by not turning off the tv then while unplug click the on off button to off the tv the plug again the tv and turn it on. and finally the red light will turn to green it means the tv is now ok! yehey. sorry for my english I'm notgood speaking english :)
Tele turned itself off, red light blinks 4 times then pauses and blinks 4 times again.
You can try unplugging it for a while and then plugging it back in, but according to the manual, the standby LED:
Lights up red when your TV is in PC power saving mode. If the LED blinks in red continuously, this may indicate the TV needs servicing.
(Operating Instructions, Page 22)
I turned my tv off, but then tried turning it back on and nothing happens. And the red light on the front is blinking. I've tried unplugging the power source and plugging it back in, but the tv won't come...
The tv power supply board is is problems and the causes.That the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
1helpful
I turned on power and red light is blinking but tv does not come on - red light just blinking no power/picture Panasonic TC-54PS14
Tries unplug,replug the tv back like an hour later.The tv now,should resetting itself back to the factory setting.The tv should work now.Not,than the tv power supply board have problems,not giving the tv it wright voltages anymore.The tv power supply board that the board,where the power a/c cord plug into it.Tries websites like Shopjimmy.com,Ebay.com to buy a whole refurbish power supply board for the replacement.
4helpful
TV turns off and power light blinks unpluged andd still does it.
Likely to be the STK convergence chips causing a protection circuit to switch the TV off. Have you got any onscreen convergence problems (i.e, colour fringes)?
4helpful
No video, shuts off then back on
I checked Toshiba's website and found the manual for the set. The self restarting was indicitive of a lamp failure. The red light was solid while the green light blinked. It would then restart 8 times before both lights would then begin blinking.
Top Sony Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
ZJ Limited
ZJ Limited
matt martin
matt martin
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
