Francisco:
Could be one of two reasons. If the compressor does not reach full pressure in the tank, you have an air leak somewhere between the tank and the business end of the hose. Run the compressor and use a soap and water solution to find the leak and correct it. Don't forget to check the copper line leading from the compressor motor to the air tank. My compressor would not pump above 45 pounds, and I had to replace the valve body (on top of the cylinder) because a valve had cracked.
