1986 GMC Truck Sierra C/K 1500 2500 3500 Neoprene Custom Seat Covers Logo
R
Ryan Smith Posted on Jan 19, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Heater fan was squealing and now is not turning on at all....
Relay is clicking but fan not coming on
xkikbxr
Level 3:
  • Master 788 Answers
  • Posted on Jan 20, 2016
xkikbxr
Master
Level 3:
Answers
788
Questions
0
Helped
228537
Points
2051
High pitched squealing or grinding is an indicator that the blower motor is about to die, I'd say yours has probably done just that.
High pitch/squealing noise ust started when I turned on my heater.
Year make and model ? Is the noise coming from the engine compartment or from under the dash ?
High beam headlamps inop
do you have halogen or hid lights sounds like a ballast or ground issue more info!!
1991 nissan maxima squealing clicking noise behind the dash
while clicking is happening place your hand on the heater blower motor and you will feel it coming from there. change the blower fan.
Toyota Tercel belts are squealing
I have been having the same problem with the alternator belt squealing, most noticeably, when using the heater fan , accelerating, turning the headlights on. I have a 1997 Toyota Tercel CE 1.5L 4cyl with no A/C. I just tightened the belt tight enough that there is no give to the belt and it does not squeal anymore.
I also used a Goodyear Gatorback from Napa belt which seems to be nice and quiet when tight enough.
98 Saturn SL2, AC/Heater Clicking
You need to replace the heater/AC blower motor the motor shaft bearing is defective..
1helpful
The fan does not turn on but the furnace does appear to heat uo
Try turning the fan on manually at the Thermostat by clicking "Fan On"...if thiis turns the fan on...leave it running and you will have heat till a Service Tech can come out....if if doesn't work you will req a Technician to have a look . Likely if the furnace is fairly new either the Relay , Circuit board relay or the motor itself is Defective.
Bill
1helpful
Heater/defrost/ac fan not coming on park avenue...can hear click
Check the connector to the blower motor. Turn it on and wiggle the connector.
Electric fireplace squeals constantly when heater fan turned on
https://www.fireplaceparts.com/10006404-fan-heater.html
This is for the pyromaster hef33 2004. This site has 02 thru 05 parts for the pyromaster.
Top Coverking Vehicle Parts & Accessories Experts
john h
Jonathan Buck
Jonathan Buck
Are you a Coverking Vehicle Part and Accessory Expert? Answer questions, earn points and help others
