Top-O-Matic Topomatic Cigarette Rolling Machine Top-o-Matic Logo
Nanci Johnson-DeRosia Posted on Jan 19, 2016
My crank wont move
It wont push the tobacco
Frank Hunter
Level 1:
New Friend:
  • Contributor 30 Answers
  • Posted on Oct 15, 2016
Frank Hunter
Contributor
Level 1:
New Friend:
Answers
30
Questions
0
Helped
51555
Points
68
Are you loading it too tightly? w/o tobacco will it move? Take the rubber bottom off and inspect a touch of oil on rubbing parts
1helpful
2answers
Why cant i get a decent cigarette out of my powermate II mach.
I am going to go under the assumption you are using 100mm tubes. I just switched to kings to make life easier but here is how I filled my 100mm to the filter with good compaction and a trick to get it to the filter. I tightly pack the tobacco against the left side, sticking my finger in the chamber and pushing pretty hard to compact to the left side, I then just do a light poke for the rest of the compartment. Here is the trick part, take a finger and put light pressure pushing on the filter towards the machine, but not so hard it bends the tube and also no so hard that when the injector probe comes out it pushes your finger away from the machine. Using this method I would get around 9 good packs with one redo out of 10 injections. The key is to have enough pressure to hold the filter at the point where the plastic tab usually pushes out and then let the probe push your finger away from the machine. Only very light pressure is needed to make the difference. If the cigarettes are not packing tight you are not compacting enough tobacco in the chamber. There is a fine line though, you need to find the balance as stuffing too much in will cause it to bind up, you just need to find the balance. Once you figure it out it will go very quick, I stuff mine while on the phone and can do around a pack every 2 to 3 minutes or so and get a cigarette that can not be distinguished from a store bought one.
Another tip: I use old cigarette packs as containers for my DIY smokes, you can do the same here with a plastic case. If I do get some that are not fully pushed against the filter using the above method, or if the pack just seems a little loos I put them aside and at the end I load them all in cigarette packs just like they come from the store, filter up (otherwise I have a habit of smoking filters from years of them being positioned this way!) and once the pack is full (add good ones if there is space for them to move around, it will not hurt them) turn the pack upside down so the lid is on the bottom. Now tap them firmly about 10 to 20 times against a hard flat surface. This will move the tobacco towards the filter if there is a space or pack loose cigarettes.
Warning: From my experience :) Do not over stuff the machine or using the compacting method do not over pack the tobacco, find a good medium. If you over pack the smokes will be solid and very hard to drag from. Do not smoke cigarettes that are hard to rag from, the extra force needed by your lungs followed by introducing smoke into your lungs will result in pain and maybe worse, but I only made that mistake once.
1helpful
Need to know what moves the thing that holds the tubes on the machine
It is called the "cigarette holder" and has a replaceable "rubber bumper" on the end. Powermatic will send you a new one if you call when it does not hold the paper on as well as new.
http://powermaticinjector.com/c2instruct.asp
2answers
The injector shaft will not push the tobacco into the tube, it seems to be jammed, how can I fix this?
that is typically a moisture level issue or too much tobacco loaded. clean it out, use the tools provided or a thin rod to clear the tube, inspect and retry.
3answers
Tobacco only goes half way down thetube
inspect that the rubber piece that holds the tube.Chance's are that it is worn and needs to be replaced. it wont hold the tube all the way if it is worn. A quick fix is to cut a piece of eraser of a pencil and glue it to the holder.
2answers
How to fix with pitchers
Remove the bottom cover panel, the rubber one. Take a photo of the inside of the machine. You'll see four little lever arms that all move together when you rotate the crank - the upper two arms rotate on screws. Remove those two screws and the upper arms will be free to move.
Now the really tricky part is getting the two lower arms free. There's one perfect spot where they come loose and the tobacco plunger (piston?) will be free to remove. At this point, you should also be able to remove the sliding guide that feeds tobacco into the cigarette tube.
It'll all go back together exactly the same way - again, it's really tricky to get those two lower arms to attach to the plunger / piston.
2helpful
2answers
Rolling 100s not filling tube up
Trick i have learned is to put a small amount of tobbaco in the chamber now move it side to side with your finger tips. Now add more tobbaco to the chamber as you normaly would.It will fill the tube better.
2answers
The handle sticks when crank to push tobacco throuh
Clean it with alcohol. Wipe it down , it removes tar and sticky residue without getting it soaking wet. Alcohol works great on ashtrays also !
4answers
Tube will not fill near filter
Trick i have learned is to put a small amount of tobbaco in the chamber now move it side to side with your finger tips. Now add more tobbaco to the chamber as you normaly would.It will fill the tube better If that does not work out for you try virginia blend tobbaco it will work better in any machine...
7helpful
Top o matic cigarette injector is only filling the cig half way
Hi Mindy,
Make sure that your tobacco is not too wet. Set some tobacco out (about the amount you plan to roll) and let it air dry for about 5 - 15 minutes. You'll have to figure out how long to let it dry as your home temperature is different than mine. Don't let it dry too much though. Give this a try. It works for me.
Take care,
Dennis Mason
Top Top-O-Matic Cooking Experts
ADMIN Andrew
ADMIN Andrew
Billie Aukuso
john h
Are you a Top-O-Matic Cooking Expert? Answer questions, earn points and help others
