I entered the wrong pin to many timws
SOURCE: i have an airtel mobile no. 9867451653 i am asked
for puk code pls contact your customer care with another airtel number and give your sim number which is written on the back of your sim card. they will give you the puk code.
SOURCE: I have a Alcatel one touch tribe phone and I have
You need to contact your carrier for the PUK code.
SOURCE: nokia xpressmusic pin blocked enter puk code
PUK code can be given only by your service provider which is specific for each and every mobile number.
Contact your sim customer care department over phone. Its free of cost to get the pin or puk no. If you cant contact through your phone get some other phone and contact them.
Go to the nearest service outlet of your service provider they can also help you.
There is no other go than the above procedure only your service provider cangive it nobody else in this world nor any software.
Go to the below link and you can confirm that the above procedure works and there is a testimonial given by the customer too. http://www.fixya.com/support/t3582685-phome_lg_ke670_put_security_code_phone
SOURCE: nokia e71x pin code blocked , enter puk code
Every PUK code is unique so nobody can tell you your PUK number, but i will tell you what you can do!
1) If you still have your packet that your Sim Card came in, you should find your PUK number in there, if you don't have the packet, please read bellow.
2) You must get a phone that is on the same network as your phone and call the networks Customer Care and ask them for your PUK number, they will ask you for your phone number, then they will tell you your PUK number. Once you have done this, you will be able to reset your Pin number so you will be able to go into your phone again.
Thank you for using FixYa!
Rate this solution
