Question about Toro Power Clear 621 R Snowblower - 38451
I put a mixture of oil gas in my 621 R/621 toro snowblower?
How do you correct the problem when you put a mixture of oil & gas when require just gas?
  • 14,690 Answers
Drain the tank,clean tank,remove bowl under carb,one screw holds it on,gas will spill out,have some rags around the area to catch gas,wipe out,put back on,then fill with gas,check spark plug if you tried to crank with bad gas.Also make sure your air filter is clean.If you can put a inline fuel filter with a on-off switch on.
Posted on Jan 18, 2016
  • Toro Master
  • 3,519 Answers
Hi Jerome:
Shouldn't be too bad.
You could disconnect the fuel line at the carb and drain the tank.
Drain and flush the carb. Reconnect the fuel line and fill with fresh gas.
If it won't start, pull the spark plug and clean/dry it with a propane torch, or replace it.
Odds are it will be fine.
Cheers.
SOURCE:
What type of gas and do I add oil to run A Toro Snowblower ccr 3650 65 hp?
there is no such snowblower made . 65 horse power is bigger than a small auto
Nov 12, 2015 | Toro Garden
Toro 621 back firing
if oil/gas mix is run thru a four cycle engine , id suspect the plug is fouled with oil , this may require replacement once your sure all the oil is out of machine completly
Feb 25, 2015 | Toro Power Clear 621 R
Toro 38451
change the rubbers they are worn out easy
Jan 27, 2014 | Toro Power Clear 621 R Snowblower - 38451
Toro 621 snow thrower won't start
could be a number of things , spark , bad gas oil mix clean plug close choke when starting open after start , umber one problem clean the tank out
Dec 15, 2013 | Toro Power Clear 621 ZR 21 163cc Single...
Toro troubleshooting
Use a funnel and tip out all the gas oil mixture. Then replace with a cup of straight gas. This should start and clear out the mix.
Run out until it stops and refill with correct gas oil Usually 8-1- see the label on the oil bottle.
Dec 05, 2013 | Toro Garden
Toro snowblower troubleshooting
adjust the cable to accelator so it revs higher ,
Oct 27, 2013 | Toro Power Clear 621 R Snowblower - 38451
Toro Power Clear 621 R Snowblower - 38451 Logo
176 people viewed this question
Top Toro Garden Experts
Joseph Mueller
Joseph Mueller
lnbn1975
roeb
Are you a Toro Garden Expert? Answer questions, earn points and help others
