Televison & Video Logo
J
Joe Good Posted on Jan 18, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Did the channel scan for OTA stations, is there a way to hold these stations so I can turn antenna and rescan for more stations?
With the new tv I get more channels than with the old converter box but It does not find some I used to get
Claude Kayser
Level 3:
Top Expert:
  • Element Elec... Master 9,098 Answers
  • Posted on Jan 18, 2016
Claude Kayser
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5066566
Points
28436
Guide to help get more channels on digital tv
spartacus-searching.com/dtv.html
Orginally there were many tv stations but the government decided to force ... Alsothese televison signals are more difficult to capture than before with analog signals. ...So that's not accurate when we are trying to find a TV transmitter. ... web page will tell you rescan for channels, thats great if you raise your antenna or have ...
How to sharpen digital TV reception via antenna
1helpful
Why does my tv continually drop antenna tv channels. I have to rescan tv several times a day
Assuming that we talking about digital channel could be couple reasons. First- too small antenna or in wrong location. Usually at evening, night hours there is less interference from cars, running electrical equipment etc reception is better. Far away stations reception is also better at night. Trees, houses etc also affect reception. If you in USA you can use site: antennaweb.org to determine correct antenna and direction to receive channels in your location.
Have lost all channel 2 stations
I assume you are having a problem with OTA channels. On some TVs, if a digital channel doesn't have enough signal strength, the channel list will get edited to exclude it. Have you checked that your antenna is pointed in the correct direction? My external antenna sometimes turns in high winds. Turning it back to the original direction improves the signal strength so that the tuner works. Then go into the Menu and find the Setup or Channels sub-menu to attempt to rescan for channels. (If you add a comment with the model of your TV, I may be able to give the specific sub-menu details for scanning for channels.)
If your antenna has an amplifier, try using the antenna without that amplifier. A few times, the amplifier/splitter attached to that external antenna has been damaged. Then the amplifier becomes a filter and blocks some channels. If you are far enough away from your local station's transmitter and can't receive the signal without the amplifier, replace it.
If another TV receives the stations, the problem is more likely to be the tuner for the TV itself. These can be damaged by a surge from the antenna. The solution is to get a set-top box with an ATSC tuner or replace the TV. Some sites may have replacement tuners (like shopjimmy.com that salvages parts from TVs with damaged screens); however I don't know if they'd have the part you'd need.
I hope this helps.
2helpful
Cable in my area has switched to digital cable. I own a Hitachi HDTV about four years old. When I scan my channels it will only scan analog channels...the digital channels are an option but I don't...
Unfortunately, you need a set-top box. The Hitachi 65F59 has an ATSC (digital OTA) and NTSC (analog) tuner. It doesn't have a clear-QAM (unencrypted digital cable) tuner.
There are a few DVR set-top boxes with QAM tuners that you can buy separately. (You will need to make sure a given model is compatible with your service. FIOS uses a different option on the Cable Card than other providers.) Alternatively, you can get a cable box from your company.
Retrevo has the manual for this Hitachi TV here: http://www.retrevo.com/support/Hitachi-65F59-TVs-manual/id/371ci977/t/2/ . You will need to enter a code to access the PDF.
If you want OTA HD, you will need to determine the correct antenna for your area and the direction to the transmitters. (External antennas pick up more stations. In some areas amplification may be needed to get a good signal.) See antennaweb.org or tvfool.com for searches on the appropriate antenna to get a signal and where to point the antenna. Antennaweb assumes an external antenna but is very conservative in the received channel list. You would need to set the TV signal input to Air and rescan for channels if you choose to go with the OTA signal.
I wish that I had better news for you.
I bought HDTV/UHF/VHF/FM INDOOR PASSIVE ANTENNA please help me to install it it is not working
Is the antenna the correct one for your environment? Do you have the antenna pointed at the stations you want to receive? Use antennaweb.org or tvfool.com to get an idea of the location and likely channels you can receive at your location. Antennaweb assumes an outdoor antenna but is very conservative in the list of channels you can receive. (These may match the limits of the indoor antenna.) TVfool lists the stations and the appropriate antenna that will likely receive each station.
Tall trees and buildings will block the signal. Get the antenna as high as possible. Move the rabbit ears and UHF loop to maximize your signal strength. Then make sure the TV is set to use the OTA tuner (ATSC for digtal stations). (That may mean changing the source in the setup menu.)
Then scan for channels. Move your antenna or parts of it and rescan or edit the channel list. (For some TVs there is a weak signal setup option that will let you manually enter the station number (including sub-channel). Then it will provide the signal strength information as you move your antenna.)
I hope this helps. An amplifier may help you bring in weak stations with enough signal strength for the tv to see them.
Plugged in, cable connected, turned on, says "No Signal"
OTA signal? Check your antenna orientation and if there are any tall objects that would interfere with the signal. (See antennaweb.org or tvfool.com for signal directions and distance to the station. antennaweb assumes an external antenna and is very conservative with station information.) Scan for channels with Menu > > (right arrow twice) up or down to AutoScan and hit enter. Use add channels to include stations with the antenna in a new direction.
If you are using the built-in antenna, you may not get digital signals. Try an external antenna (see above sites). Digital signals are enough or zero.
This TV doesn't have a cable tuner so a set top box would be needed for cable stations, check the box directions for the station you need to tune the TV to access the signal.
I hope this helps.
Poor reception on one tv channel only rest are fine
If OTA, check that your antenna is pointing at the station's transmitter. Look at antennaweb.org or tvfool.com (antennaweb is very conservative with the stations that it will suggest that you can get. Both assume external antennas.) If you have an amplifier, check if it is working (I lost a local VHF channel recently when the antenna splitter/amplifier got a power surge after a lightning strike - despite it being the nearest station.)
Consider resetting the tv to the defaults and rescanning for channels. (The reset is under Menu > Picture Settings > Advanced Settings (if you use Customized Picture Mode; there is a second reset under Audio settings for those customized functions.)
I hope this helps.
My TV Sharp 26 SB1 LCD PBS channel breaks up
Do any other OTA channels break up on this TV? Look through your setup options menu for a TV reset (memory or restore default or a similar command) . Do the reset and exit the menus (save the action on most TVs); then return and rescan the OTA channels.
On a different brand of TV this worked. The channel had broken up for several weeks; the reset was used when the channel finally became totally corrupted (no video on one sub-channel, no audio on the other).
Some tuners need a stronger signal to be stable; you may need an amplifier on your antenna.
I hope one of these ideas helps.
1helpful
My viewsonic N3751w LCD TV won't receive air signal. It has a built-in digital tunner so it should be able to receive several air signal without a need to have a digital to analog converter
Check that your antenna is sufficient for your location and oriented correctly. Try antennaweb.org for the most likely channels; tvfool.com has a much greater list of channels and the antennas needed to receive them. Both sites assume external antennas and warn that trees and buildings around your location may cause interference.
If you have a splitter connecting one antenna to several TVs, consider using an amplifier to ensure that the TV gets sufficient signal strength. Remember digital TV is has all-or-nothing reception issues.
If you previously could pick up the stations with this TV and suddenly lost them, try resetting your TV. Unplug the unit for at least 10 seconds. Also restore the factory default settings and then rescan for all channels. The reset is possibly Menu, Options, Restore Default or Menu, Setup, Memory Recall. (Viewsonic has changed its menus at intervals so look for something similar). Once you find it, click enter then left or right arrow to YES, hit enter again. Then hit menu twice to exit the OSD menu and then re-enter the menus before trying to rescan channels.
Also check that the TV is looking for OTA and not cable signals. Check that the tuner is still working by retrying the scan in a spot you know that the antenna captures a stations signal. Make sure your antenna cable hasn't been damaged by anything.
If you recently had a power surge (lightning strike) near the antenna or cable, you may be in need of a new tuner. (BTDT with an older TV)
I hope this helps.
Are there any boxes that don't require 'autoscan' for setup?
How to connect a motorola DCH3416 to a computer?
2helpful
Turn tv on and get no program or weak signal message.
You should be watching tv in no time. Email me and let me know how it went I would like to know if I was able to help. [email protected]
1-You didn't say what model tv you have. Is it a HDTV?
2-Are you using an over the air (roof) or set top antenna connected to the tv?
3-Are you getting the no program or weak signal message on all channels?
4-Have you tried first cycling through the source or input button to make sure you are on TV and not on an input. Sometimes if you are on an input and for example the device connected to that input is off you wil get a no signal until you turn the device first but you probably already know that.
5-When you were in the process of scanning for channels assuming you had an over the air antenna connected did you make sure and select the ota option and not cable? if you have an ota antenna and not cable you need to select ota before scanning for channels.
Now assuming you have an ota antenna and you chose ota before scanning or doing a re scan and after the scan you still get the no program or weak signal message that means there is no signal and you may be using the wrong antenna or try moving the antenna in the direction of the television tower if you know where that is or turn in another direction but unless you are using the wrong antena you should get something.
Assuming you received some channels or even if you did not, try to and add channels by hand. Heres how: first you need to know the RF frequency channel or digital channel its transmitting on you just cant input the number of the display channel you want like on a tube at least not initially but you can after you first input the rf or digital channel number first and saving it on your tv then you can just input the display channel number you are used to. Heres how to manually force the tv to enter a channel without a scan or re scan and possibly loosing other channels with a rescan.
Go here http://www.rabbitears.info/search.php and go to state search choose your state from drop down list and click search now do you see the list of stations? on the left you have the display channel (thats the number you usually entered on a regular tv) and next to that is the digital channel (thats the number you need to enter on an hdtv or dtv initially to force the tv to accept the channel because if you just enter the number your used to initially the tv wont find it) the tv should now automatically redirect you to the channel you are normally used to and any digital equivalent and any sub channels for that channel. Now save it into memory in your tv menu channel list. do this for every channel for your area if you were unable to pick up any stations during a scan.
Top Element Electronics Televison & Video Experts
Grand Canyon Tech
Grand Canyon Tech
Are you an Element Electronics Televison and Video Expert? Answer questions, earn points and help others
