The power light light blinks for about 5 times, and I've told it could either be the power supply or the led. i had a tech come over to fix it, and he said it was the led that needs to be replaced. I'm not sure because he said he swapped out just the main board, and still not working.
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
Testimonial: "ok, thank you. i'll try."
