Adhesives, Coatings & Sealants Logo
A
Anne Rudolph Posted on Jan 17, 2016
I NEED KEYCODE TO ACTIVATE A UNIVERSAL REMOTE ORIGINAL IS BROKEN THE GUIDE DOESNT HAVE THIS BRAND OF TV
5 Related Answers
Anonymous
  • 3130 Answers
  • Posted on Jul 06, 2006
SOURCE: my remote control does not work
You could have a defective IR sensor in the tv set that sends the infared signal to the MIcroprocessor IC. These are something you cant just replace, as it needs to be trouble shot with a scope to see if theres a data signal comming out of the sensor and if there is it could be a bad solder connection somewhere between the sensor plug to the Main IC. Also could be the B+ that supplys voltage to the sensor. Unless you have had electronic repoair experience, You should have a pro assist you with this repair. Sorry I couldnt assist you more with this . Good Luck
Anonymous
  • 12 Answers
  • Posted on Sep 30, 2008
SOURCE: Tevion TV with no compatible universal remotes
www.1800remotes.com
rulds2008
Grand Canyon Tech
  • 3867 Answers
  • Posted on Jun 12, 2009
SOURCE: Dora 13 inch tv remote broken
www.remotes.com will have that remote that will work for you. I would not recommend anything diffrent.
Thanks and good luck!
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/edwy_1a56970cf1ea4620
Anonymous
  • 2335 Answers
  • Posted on May 01, 2010
SOURCE: I need a universal remote code for a Polaroid LCD TV FLA-3232B
I may be able to help with your Tevion Universal remote and your Polaroid LCD HDTV.
You can find some Polaroid HDTV Remote Codes here.
I hope that helps.
______________________________________
Polaroid FLM-3232 Manual Download
Polaroid FLM-3232 Service Manual Download
Anonymous
  • Posted on Feb 13, 2011
SOURCE: I own a Radio Shack
Go to this link:
http://www.radioshack.com/product/index.jsp?productId=3964905#tabsetBasic
Scroll down to product support and download the
RadioShack® TV/DVD Remote (Addendum - Code List)
And you will have the pdf of the remote codes.
How to activate universal remote control AMELY AD-UL101S with LG TV Brand or other brand?
Question edited for clarity and add maker.
No one uses Universal Remotes these day. You buy a Remote that is a Copy of the original.
https://www.fixya.com/support/r29872378-universal_remotes_no_facsimile_remote
The AMELY is a very cheap and nasty Chinese Remote and they don't supply instructions!!
https://www.amely.cn/AD-UL101-S-AMELY-unviersal-TV-LCD-LED-remote-control-p636185.html
Codes are decided by the brand of television. This is for LG
https://www.google.com/search?q=universal+remote+codes+for+lg+tv
1helpful
How do you auto tune a Changhong TV Mod No LED3207b if you dont have the remote?
Grab best holiday deals and discount up to $50 on flight tickets to India:
www.tripbeam.com
www.airfarebooking.ca
www.flyopedia.com
www.tripbeam.ca
Remote wont pair with tv
If you wish to buy its original remote control, contact the authorized service centre, or authorized dealer to your device brand.
To select a proper universal remote control, you should know about the number of digits to its set-up codes. There are 3 digit, 4 digit, 5 digit, 2 digit and even single digit codes, to some brand devices. After confirming this, check the sites linked here. Both the sites have set-up code list and set-up procedure to many popular brand remote controls. Check which brand remote control has set-up code/s to your device brand, and buy that one according to availability? Brand name of the remote control isn't a matter, but it should have set-up codes in its code list, to the device you have.
Please note: Every new universal remote control will have set-up code list, and set-up procedure along with its user manual. Never accept a remote control, that hasn't both of this. If you see the site by "MOSAIC" or "Magazine" view, will make surf easier.
http://electrohelponline.blogspot.com/
Universal remote controls are available at most of the electronic spare part selling shops.
Check this link too. http://remotesearch.blogspot.com/
Universal remote code
Check these links. There is code list to many popular brand remote controls. Select one among them, which will give you maximum functionality to your TV. It is not predictable, which code will give you appreciable effect. Try one by one, and select one which you feels good. Never expect that all the functions will be correct in activating, as the buttons indicated in a universal remote control. [Original is Original, and Universal is universal] OK?
http://electronicshelponline.blogspot.com/ http://remotesearch.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Need code to set rm/v301 universal remote control for Wansa TV
Your right that remote does not have the codes supporting that model but personally I would try the following codes of 055, 026, 012, 013, 003 (based on Samsung ) as originated may be the closest you will find to this. Other than that your all in 1 is no good unfortunately.
Ge universal remote code for mintek dvd players
You most likely will not be able to find a code for it because it is an off brand (not-so-well known brand) and most universals will not have codes for that brand. if your universal remote doesnt have codes for the Mintek brand or has them and they dont work then, sorry that remote will not work for you. you will need to try and get a different one. or try and get the original remote. you can try finding the original remote at ReplacementRemotes.com by typing in the model of the Mintek DVD player. or you can try Ebay.
Remote Broken
brantex,
If you're looking to make the universal work with the Insignia Tv you need to research the remote (model/brand) to the Tv. You can do this at: http://www.remotecodelist.com/remotes/
It would be my strong suggestion however that you purchase the original because no universal remote will allow you access to the service menus and all the features.. You can buy the original for about $32.00 plus shipping at : http://remotes.com/?OVRAW=Replacement%20Remote%20Control&OVKEY=replacement%20remote%20control&OVMTC=standard&OVADID=4084295511&OVKWID=10268551011
Hope this helps!
Bill
Top Maxess Climate Control Technologies Adhesives, Coatings & Sealants Experts
ADMIN Andrew
ADMIN Andrew
Are you a Maxess Climate Control Technologies Adhesive, Coating and Sealant Expert? Answer questions, earn points and help others
