Unable to print anything else from computer.
SOURCE: epson lq 2090 matrix printer
This may be a mechanical problem- perhaps the belt which pulls the printhead back and forth is slipping a cog tooth in the drive mechanism. Check this belt for proper tension, and that the cogs are in good condition.
There is also a home sensor located at the left-hand side of the printhead movement area which sets the home position of the head, and from this, the start of printing is determined. If this home position sensor is defective, this will cause problems. One certain Epsons, this sensor was a switch, and this would become erratic.
These are possibilities to check...
SOURCE: printer will not print anything. Ink levels are
If it has been longer than 3 or 4 weeks since anything last printed, the problem may be clogged print heads. Run thru several cleaning cycles and see if anything begins to appear on the paper. If not, changing the ink cartridges may solve the problem. If it's been quite a long time since last printing, you may need new (and expensive) printheads. If that's the case, replacing the printer would be more cost effective. Sorry for the bad news.
SOURCE: WE ACCIDENTALLY SENT TWO FORMS TO PRINT FROM
Microsoft has the help you need for this issue and I wont try to give you long and possibly misleading information on here.
It is a common problem but the answer is here
http://support.microsoft.com/kb/946737
You need to refer to method "D" about half way down the page
Once you clear the print job check you dont have any extra printers installed as quite often happens in these situations. If you have then delete your extra printer installations.
SOURCE: it will not print or scan-keeps saying computer and
Hi there
This could be the driver, add and remove driver close down the PC then re start and reinstal driver it worth a go it may be just that.
All the best Pineworks
SOURCE: sharing two computers won't complete print jobs
ok forst of all you should re install the drivers of printer and re cheak the both of the computers re configure all if not solve then tell me again.
