Freezers Logo
k
kathy feris Posted on Jan 16, 2016
2007 Fridgedaire Upright Model LFFH2067DW2 red light is on on the front - what does that mean?
On the front door it has always had an amber light on but now a red light is on. what does that mean
1 Related Answer
kachbibi1
Bill Dickerson
  • 979 Answers
  • Posted on Mar 03, 2013
SOURCE: I can't find the temperature control knob! I have a Frigidaire upright freezer model number LFFH2067DW2.
Otherwise it would never stop freezing. Let me know what you find out.
Kenmore upright freezer problem
Kenmore Freezer, lights on and loud buzzing sound. - Shop ...
www.shopyourway.com > KRISTI PETERSON > Questions
I have a Kenmore upright freezer model # 253.26052104 and at the bottom of the front there are two lights and an on/off rocker switch. At this time one light is ... When I attempt to turn it back on, it makes an extremely loud buzzing sound. What does that... The switch that you are describing is for the high temperature alarm.
Kenmore rocker switch Freezers Questions & Answers - Fixya
www.fixya.com > Forum > Tags > rocker switch > Freezers
Kenmore freezers rocker switch related questions and answers. ... Kenmore upright Freezer 20.3 cu.ft has 2 switches on the bottom of the freezer and was making a loud buzzing sound like an alarm and the ... How to turn off the doorajar beeping on aKenmore Freeze and what is causing the moisture buildup inside freezer.
GE 14.1 cu. ft. / 399 liter Upright Freezer FUM14DMRWH
My frigidaire automatic defrost upright freezer gets ice build-up at the top right at the front any suuggestions
This is just a general answer but it may mean that the door seal is leaking. Try running a dollar bill under the seal to see if that area is looser than the rest of the door seal.
Look inside the freezer for model number.
How to Check Freezer Door Seal DoItYourself com
1helpful
I need a manual for Frigidaire LFFH2067DW2
Good Afternoon Friend,
I understand that you are in need of a manual for your Frigidaire freezer, model# LFFH2067DW2. I also see it is barely cold inside your appliance and the door is easy to open. I would suggest contacting the manufacturer for a copy of the owner's manual. In regards to your freezer being barely cool and the door opening easily, it sounds like the seal might possibly be compromised. I suggest checking the seal of the door, making sure that it is not damaged in any way. I ask that you please follow up with a comment on the post, at your convenience, to advise if further troubleshooting is needed or if your appliances status has changed successfully. Hope this is helpful.
-Best Regards-
WP
Ridare freezer alarm goes off and it wont freeze ice c ream
Hello grega1959 - If the temperature of food rises to an unsafe level, the buzzer will sound and the red light, if equipped, will also glow. First, deactivate the alarm to the unit. This can be done by either by unplugging it or flipping the household circuit breaker. Wait approximately ten minutes and then turn on the freezer. After deactivating the alarm and the unit has run approximately four hours, the red light/alarm should go off on its own. If the red light/alarm continues to stay on, the freezer may possibly have a communication problem with the temperature control, control board, or a wiring harness. If this is the case, I would recommend connecting with a professional appliance tech for a clear-cut diagnosis.
Freezer model LFFH2067DW2 - shut the door on an extension cord that left the door cracked open overnight. The alarm was on and has not cleared after four hours. How do I clear the alarm?
Hi, It likely will tell you in your owners manual, but if you push & hold the alarm button it should stop after several moments ( I think it may actually be 30-60 sec.) That should reset the alarm. However, if the thermistor senses the temp. to be too warm the alarm will return. Hope that helps, let me know. Good luck.
What are the lights?
I cannot find any manual or information on the 3 lights. I would assume that the green light means everything is OK, the red means current problem, and the amber means manual defrost is due. Sorry, this is the best I can do. Later.
Top Freezers Experts
ADMIN Eric
ADMIN Eric
ADMIN Andrew
ADMIN Andrew
Are you a Freezer Expert? Answer questions, earn points and help others
