I CONNECTED MY SONKEN 2000 KARAOKE MACHINE AND Tascam MD-CD1 MK3 MiniDisc CD Recorder / Player VIA OPTICAL HOSA CABLE BUT PROBLEM REMAINS. THE MANUAL STATES I SHOULD CONNECT THE Tascam MD-CD1 MK3 MiniDisc CD Recorder / Player DIGITALLY. I AM USING A YAMAHA MGXU 20 MIXER. PLEASE ADVISE ME HOW COULD I START RECORDING FROM THIS UNIT. THANKING YOU KALINGA
It is much easier to use an analog mixer and microphone thru the mixer. I would plug the microphone into the mike input on the mixer and then the Karaoke machine to stereo LINE inputs on the the Mixer, then Mixer Output or Tape Output on the mixer to analog LINE IN on the MiniDisc recorder.
Let me know if you need more info.
SOURCE: mini disc recorder question
Just use the first two tracks, one for left and one for right and use the PAN pots to adjust the stereo positioning. Just run the 'tape out' or 'line out' or 'aux out' of the mixer to the REC "IN" on the MiniDisc recorder; hit "record" then the "play" button to start it. Make sure your input selector switch is on ANALOG and not DIGITAL or OPTICAL. Let me know how it works out for you. Okay? Thanks
SOURCE: tascam md-350 "cannot copy" error
You do not need any cable for copy data it isn't that complex, you just need a right software which is Long Path Tool to copy anything anywhere.
