Question about HP LaserJet 3050 All-In-One Printer
My HP LASERJET 3050 DOES NOT MAKE COPY,IT WORKS OK WHEN USE AS A FAX.
  • Robbie Goodwin Aug 29, 2016
    Working OK as a fax suggests that the scanner portin is working.
    What happens when you try to print, please?
SOURCE:
SOURCE: low memory on HP Laserjet 3050
low memory error on my hp laserjet 3050
can anyone help
Posted on Jan 12, 2008
  • 10 Answers
SOURCE: HP LaserJet 3050 Fax
for Teeshot: Make sure your line is plugged in the correct spot (line icon, not phone icon). I had the same issue and this magically solved it. the cable got unplugged for some valid reason and plugged back wrong
Posted on Oct 20, 2008
SOURCE: hp laserjet 3050 - black line down the center of
If the lines only appear on copies from the auto feeder and printing is clean, then lift the auto feeder section and clean the scanner glass underneath.
If printing and copying have similar 'streaky' results you probably have a bad toner cartridge - try a replacement. If that doesn't work you have a fuser problem - which is quite a costly repair based on the replacement cost of your unit
Posted on Mar 04, 2009
Dadofmykids
  • 25 Answers
SOURCE: how 2 configure fax on HP laserjet 3050
If this doesn't answer your question, then let me know more specifically what you need.
Setting the time and date
To set the time and date
To set or change the time and date, use the following steps. If you need help entering any
information, see Enter text from the control panel.
1. On the control panel, press Menu.
2. Use the < or the > button to select System setup, and then press .
3. Press Menu to select Time/Date.
4. Use the < or the > button to specify either the 12-hour or the 24-hour clock, and then press .
5. Use the alphanumeric buttons to enter the current time.
6. If you specified the 12-hour clock, use the < or the > button to move the cursor past the fourth
character. Select 1 for A.M. or 2 for P.M., and then press .
-or-
If you specified the 24-hour clock, press .
7.
NOTE Make sure that you use two digits to specify the month and day, in that order (for
example, use “05” for May and “01” for the first day of the month of May).
8. Press Menu.
Setting the fax header
To set the fax header
To set or change the fax header information, complete the following steps. If you need help entering
any information, see Enter text from the control panel.
2. Use the < or the > button to select Fax setup, and then press .
3. Use the < or the > button to select Fax Header, and then press .
4. Use the alphanumeric buttons to enter your fax number, and then press .
5. Use the alphanumeric buttons to enter your company name, and then press .
NOTE The maximum number of characters allowed in the fax number is 20. The maximum
number of characters allowed in the company name is 40.
Posted on Apr 07, 2009
FixinFax
  • 3085 Answers
SOURCE: HP Laserjet 3050 All in one printer - Unable to receive faxes?
Vonage is dgital. fax machines are analog
Posted on Jun 26, 2009
Distorted copy quality in the sent faxes
Make sure the rollers that pull the paper through are clean and that the glass is also clean. Clean the rollers with a cloth dampened with alcohol.
Apr 20, 2009 | HP LaserJet 3050 All-In-One Printer
Remote fax retrieval
yes, go to menu and find "reprint last faxes" than press ok
Feb 25, 2009 | HP LaserJet 3050 All-In-One Printer
Paper jam in the automatic document feeder
I have a Laser Jet 3050..when I try to load a oaoer to copy or fax, paper does not move...just gears moving but paper is not being pick up...any solutions?
Aug 01, 2008 | HP LaserJet 3050 All-In-One Printer
Troubles with copying
Pull the Top Loading Document Feeder up towards you from the back, to open and view the clear strip (perspex). I also had this problem, and fixed it by cleaning this strip. for future reference don't use whiteout on papers your going to fax/copy ;)
Feb 07, 2008 | HP LaserJet 3050 All-In-One Printer
Faxes sent through HP 3050 is unreadable
Following could be the reason behind this issue:
1. Check ink cartridges of the recieving printer.
2. Make a copy from your printer,if there is any problem while copying then replace the printer.
3. If the copying is not fine then clean the scan feeder, andif it is fine then it is an issue wih the other printer.
Jan 22, 2008 | HP LaserJet 3050 All-In-One Printer
Hp laserjet 3050
make sure u go to the HP site and download the latest version of HP operating software or u will need to contact HP support
Dec 30, 2007 | HP LaserJet 3050 All-In-One Printer
HP LaserJet 3050 All-In-One Printer Logo
Clive
Clive
Ekse
Thomas F. Schneider
